WIND!
Discussion in 'Gen 2 Prius Main Forum' started by adamsbj, Apr 6, 2007.
  1. jesart
    jesart Junior Member
    84
    These past couple of weeks we've had some serious gusts out here in SOCAL. I concur, the Prius is not the best choice vehicle to sustain high winds. I was tossed around on the freeway by 40mi per hour winds. It's scary when you have a couple of semi trucks next to you. I'm thinking of adding the BT Stiffening plate and upgrading my tires.
  2. donee
    donee New Member
    2,956
    197
    Chicagoland
    <div class='quotetop'>QUOTE(qbee42 @ Apr 7 2007, 04:12 PM) [snapback]419473[/snapback]</div>
    Hi Tom,
    I agree. That is why I did the tests with out any steering at all. Until one realizes how long the time-constants are on an unmodified Prius, one can easily induce the PIO (pilot induced oscillation).
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(donee @ Apr 7 2007, 05:24 PM) [snapback]419539[/snapback]</div>
    I know PIO. I bounced nearly the length of a fairly long runway one time doing exactly that. I should have gone around, but pride made me fight it out. It was on of my first times solo in a 172, and I wasn't used to the very light wing loading. I carried a bit too much speed into the landing, bounced, and then over controled my way down the strip: bounce, bounce, bounce (insert bits of profanity between bounces.)
    Tom
  4. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Adam1991,
    Well, I am an highly trained engineer. And the only time my engineering work has been overseen by a lawyer is when making patent applications. Actually, its been more like me overseeing the work of the lawyer. to be sure what the lawyer put on paper is accurate.
    Yes cars are designed as systems. And as far as handling goes some companies do it better than others. Honda, VW and Porshe have good reputations for handling, but I am not sure if there is any real testing of cross wind resistance done. Even if somebody was the "cross-wind handling engineer" how could he/she test the results of his system design? Are there even any wind tunnels that can turn the car sideways while the car runs on large diameter rollers (so the car is not held on-course) ? Are there even any automotive wind tunnels that can gust? Not all effects can be statically determined. I mean there are allot of various rubber pieces between the road and the chasis. And when which one deflects can effect the outcome. Its a long way from Japan to a midwest USA springtime highway. Are there any interstates in Mongolia for so they might test closer to home? What if that year there were not any of these 40 mph gusty conditions. Does not happen every year, or neccasarily during daytime, without rain.
  5. Godiva
    Godiva AmeriKan Citizen
    10,339
    I've got the BT plate and it did cut down on the buffeting.
    I also bought the BT tech spoiler. The first time I put it on it started to lift on the edges. I took it off, completely cleaned it and Brian sent me a kit to re-apply it, but I haven't had a chance since. It's either been too cold or I've been busy. I haven't had the problems significantly enough to make the time. And to tell the truth, I'm not sure I'm looking forward to having to take then thing off again if this second kit fails to sufficiently adhere the spoiler to the rear glass.
    I highly recommend the BT plate.
    But for the $150.00 it cost me, I consider the spoiler a waste of money. I haven't read any threads about it recently so either its effectiveness isn't as significant as the plate or Brian never ironed out the kinks of getting it to stick and its not being sold anymore.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    <div class='quotetop'>QUOTE(Godiva @ Apr 7 2007, 04:01 PM) [snapback]419583[/snapback]</div>
    I had pretty much the same experience you did. I would also recommend the BT Plate. I thought the spoiler did work and it seemed to provide some stability when trucks went by. Unfortunately mine came unglued too and the kit Brian sent to restick it didn't work either. I contacted Brian some time ago and he said he was working on getting some better adhesive. I hope he does because I would like to try it again.
  7. Godiva
    10,339
    Yeah, that's the last I heard, but I haven't head anything since. I figured I'd skip the second kit and wait for the third fix. Then wait for someone else to try it and see if it worked any better than the first two.
  8. malibucarl
    malibucarl Member
    237
    Malibu, Ca
    <div class='quotetop'>QUOTE(Godiva @ Apr 7 2007, 07:01 PM) [snapback]419583[/snapback]</div>
    I also bought the spoiler when I bought my first BT Plate. When I read about the troubles re sticking I never installed the thing. Are you expecting another adhesive from Brian ??
    Love the plate. Have it on both the new cars.
    Carl
  9. Godiva
    10,339
    I don't know. I sent him an e-mail asking if there was a better fix.
  10. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    <div class='quotetop'>QUOTE(Bill Merchant @ Apr 6 2007, 10:16 PM) [snapback]419221[/snapback]</div>
    <div class='quotetop'>QUOTE(adam1991 @ Apr 7 2007, 05:10 AM) [snapback]419325[/snapback]</div>
    <div class='quotetop'>QUOTE(adam1991 @ Apr 7 2007, 08:02 AM) [snapback]419352[/snapback]</div>
    <div class='quotetop'>QUOTE(adam1991 @ Apr 7 2007, 11:12 AM) [snapback]419439[/snapback]</div>
    Where did I tell anyone to inflate their tires to an incorrect pressure? I mentioned that some members, in fact many, choose a different pressure. The maximum pressure specified by the TIRE MANUFACTURER is far from meaningles.
    Adam, you are a jerk.
  11. qbee42
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(Bill Merchant @ Apr 8 2007, 03:24 AM) [snapback]419734[/snapback]</div>
    Aw, what do they know about tires? :D
    Tom
  12. jiepsie
    jiepsie New Member
    267
    <div class='quotetop'>QUOTE(Bill Merchant @ Apr 8 2007, 09:24 AM) [snapback]419734[/snapback]</div>
    I can understand Adam's comments, even if he did not say it very tactfully. The tire manufacturers know the limits of their tires, but cannot know what the effect of a particular tire pressure is on a particular car. So you can assume the tire won't explode, but that does not make it safe.
    There's a thread that points out the dangers of not sticking to the pressures recommended for your specific car, as specified on the door sticker. And safercar.gov says this:
    Overinflating tires can adversely affect vehicle maneuverability, make the ride harsher, and sometimes lead to loss of control and crashes.
    So anyone deciding to follow any advice found on this forum overriding the tire pressure recommended by the sticker on THEIR car (Touring might be different from base, European different from US etc) does so at their own risk. Anyone recommending such a change should realize and mention the possible danger involved.
  13. adamsbj
    adamsbj New Member
    UPDATE:
    Since I started this thread, we took the Prius in to the dealer to get the alignment looked at. They confirmed the front right was delviered out of allignment. They now claim all tires are in align...and the car no longer pulls to the right while stopping. But now it appears the steering wheel does not quite center when tracking straight.
    However, this did not help the tracking or control in the wind. We placed an order for the $165 piece of aluminum (BT Plate) this evening hoping that this would help. Don't really understand why the plate has to be machiened and thus adding a lot to the cost...
    I will report back when we get the plate installed - we are keeping our fingers crossed that it will be a noticable difference.
    BA
  14. JaviNOS
    JaviNOS Mod Freak
    150
    Puerto Rico
    Well I used to have the same problem...
    It might be my imagination haha :D but after I installed the BT plate and the toms upper strut bar it all seemed to even out... If i feel anything its minimal... and i guess the TRD suspension may fix that
  15. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    Posted in wrong thread, sorry.
  16. jackovalltrades
    jackovalltrades New Member
    45
    A little over 4K miles on my Pri now and I got my first bout with the wind issue last night. I drove onto the interstate and from the onramp had to merge between two 18 wheelers. I must have been driving about 60mph but felt the Pri swaying back and forth while following that truck. Luckily I had to get off the next exit but having driven many vehicles over the years I can say that this was by far the worst handling under the conditions. Personally, for me it wasn't a safety issue as much of an annoyance.
  17. larkinmj
    larkinmj New Member
    1,996
    I've had my Prius since Jan. 2006. Everything is stock; tires are at the manufacturer's recommended pressures. I live in New England, where it tends to get windy, and I drive over a suspension bridge to work everyday. I have not found any problems due to the car being unduly buffeted by wind. My last car was a Honda Element, which is a box on wheels, but I have owned a variety of cars and can't say that the Prius is any worse in windy conditions than the others. Maybe I just have good alignment on mine. I might try the BT plate and I will probably upgrade wheels/tires in the interest o improving handling, but so far, no wind problems.
  18. Boucher187
    Boucher187 New Member
    33
    Scranton, PA
    <div class='quotetop'>QUOTE(ABQ Prius @ Apr 6 2007, 11:55 PM) [snapback]419208[/snapback]</div>
    I have also had my Pri for about 1.5 weeks. I LOVE it thus far. I have noticed that on my trips to work along interstate 380 in the Pocono’s, PA I do feel unstable. I did not try any tactics to help this yet. Just held on to the wheel with 2 hands. I am going to try to correct the air pressure to 42/40. Does everyone ride with that?
  19. Trevor
    Trevor Member
    352
    Staten Island, NY
    <div class='quotetop'>QUOTE(Bobby @ Apr 13 2007, 12:02 PM) [snapback]422681[/snapback]</div>
    I don't think that there is a single thing that every prius owner does. I have mine at 40/38, but I did drive for 35/33 for months. I'm still running stock everything without any major issues after 15,000 miles. Not sure if I just got a good one or if I'm less sensitive than others. The only time I have been blown around was a night where the winds were so bad that everything else on the road including trucks were having a hard time keeping in a lane.
  20. PriusBoyAZ
    PriusBoyAZ New Member
    62
    I don't believe that there are "good" Prii (plural, correct?) and "bad" Prii when it comes to this wind issue. They are all built to the same tolerances. It is the shape of the Prius that causes issues from side winds -- head-on or tail winds most likely don't cause much such issues, if any.
    I drove my partner's GM truck the other day, and it was buffeted as much as the Prius -- the only difference is that with the Prius, it is very easy to overcompensate because of the high steering sensitivity.
    Also, adding tire pressure will actually make your car LESS stable. Lower pressure puts more rubber on the road, giving you wider shoes and increased stability. Higher pressure will actually reduce your footing and give you a stiffer ride. The latter will exacerbate the effects of wind or any other external impacts, as they are more efficiently transmitted to your steering column.
