Window Belt Molding Repair
Discussion in 'Gen 2 Prius Main Forum' started by Frontporch, Oct 9, 2019.
  1. Frontporch
    Frontporch Active Member
    536
    123
    Nj
    I have outside rubber issues on my 2007 prius. First the hatch release cover turned to goo and now all of my belt moldings are shot.
    Call me cheap, but after replacing the driver's molding for $35, I decided to refuse to pay over $40 for each of the other moldings. I hate to replace something that has never failed on any other car I have owned. I am going to attempt a DIY solution. Anyone else try this with success?
  2. PriusCamper
    PriusCamper Senior Member
    13,263
    5,358
    Pacific Northwest, USA
    What kind of solution are you thinking of?
    As for rubber for rear hatch release, the road crud seems to have a negative effect on that material, a known problem. Not sure what your concern is with belt moldings? Any type of armor all or similar project should keep that stuff looking brand new. Is it possible you used the wrong kind of product on it that dried it out / oxidized it or something?
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Easy & cheap fix for the hatch release cover:
    It does require taking the inside panels off the hatch and removing the garnish to properly install, but it's not hard to do.
    The window moldings do seem a little over priced, but they only take about two minutes each to replace.
    It's not so much the looks. It's that the felt part comes off and that make black goo streaks on the glass. I've had to replace three of them so far.
  4. Frontporch
    536
    123
    Nj
    I did find that same hatch button cover. Dealer should sell it rather than the entire assembly.
    My belt molding dried up and cracked between the window scraper part and the casing that fits onto the door. Hard to describe. I can post pictures tonight. I was going to try and replace that rubber window scraper part of the belt molding.
    Where the molding contacts the glass, there is that felt surface. Not sure how to duplicate that.
    I agree that it might still be one piece had I applied silicone or some other sealer. Never did. Previous owner never did. Probably never did to any of my cars and this is the first failure like this. I appreciate that the "important" things on the car Toyota got right.
    donbright and PriusCamper like this.
  5. PriusCamper
    13,263
    5,358
    Excellent example of how cleaning and detailing a car is so much more essential to proper long term maintenance than people realize...
  6. Frontporch
    536
    123
    Nj
    I can't agree. I think there are very few people that really care for their cars like you do. That's not saying you are wasting your time. Its great.
    I believe that Toyota dropped the ball every now and then on their rubber compounds. The felt on the back of the belt molding should not come off in Tampa, Fl. How about that hatch switch cover. Hardly sees daylight and yet it turns to goo. Those belt moldings shouldn't crack off in 10 years... even on back windows that recieve almost no use. Toyota is more to blame here than me or the previous owners.
    "The views and opinions expressed in this post are those of the authors and do not necessarily reflect the official policy or position of Toyota Motor Corporation"
  7. PriusCamper
    13,263
    5,358
    Yea... Living in Florida is different than living in the PNW, as well... Up here it's so often cloudy and so many places are super shady and tree debris causing car damage up here is a way bigger issue than UV damage. I've never once seen that problem with the felt on any of the cars I've worked ever, but cabin air filters getting clogged and vent servos failing from too much tree debris, it's been a problem with every car I've owned no matter how clean I keep 'em.
  8. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    I bought a used 2007 last year with the same problem. I am guessing it might be because my 190k Prius had a long life in Arizona and Texas before it came to me, but I really have no idea.
    What I did was to keep going to local junkyards - eventually I found enough that had not deteriorated and swapped them into mine. It was a bit fiddly to get them out, I cracked some of the little tab things that hold them down into the door channel.
    Interesting that I also had an extremely gooey melty case of the trunk switch, took me a few hours to fully clean/repair that.
  9. PriusCamper
    13,263
    5,358
    I wish everyone in the Gen2 forum was this sensible...
  10. donbright
    241
    151
    33
    oklahoma
    well... it did take me about 5 trips over the course of several months... maybe not the easiest way to save $100 but i enjoy the junkyard experience.
    PriusCamper likes this.
  11. Frontporch
    536
    123
    Nj
    Well. I thought of that too but at the local u pull it yards here it is kind of hard to get the window down with no keys or battery. They also understandably don’t want you to pull a 5$ parts off what might be a $100 door. All that said you have my respect for getting them off in one piece. I removed one and eventually turned to pliers for help
    Just to be clear. There are issues with their rubber. I saw some 2004s with good seals. I bet they didn’t moisturize their seals any more than I did
    Oh and I agree. Nothing better than a walk in the scrap yard
  12. Frontporch
    536
    123
    Nj
    Its been a while and I never did try to manufacture my own molding. surprising that at this point the originals haven't cracked off and blown away. I did come across a listing on Ebay for $66 for a complete set of new belt moldings even though I only need the 3. I will post back with my take on the quality of these moldings.
    Wouldn't be surprised if they come from the same factory as OEM replacements.
    PriusCamper and donbright like this.
  13. cdogpro
    cdogpro New Member
    Salt Lake City, UT
    I actually bought the same set from eBay for my 07 Prius and installed them a week ago. The quality seems solid IMO. Time will tell of course, but it is a HUGE improvement over my old deteriorated molding.
  14. Frontporch
    536
    123
    Nj
    I just installed 3 of the 4 molding. My driver's door was a recent replacement with an OEM part. I found the ebay moldings to be different but obviously made for the prius. They were thicker, so not a perfect match for what was on there The clip on the passenger door didn't quite line up, and even though they could have been on a rail, they were molded to the part so I couldn't fine tune it. That modling is about 1/8" further forward that it should be resulting in a slight gap at the rear of the window sraper. The back modlings were a good fit, but the channels didn't audibly snap in and the back clips didn't engage like they should have, leaving a gap that is noticable between the molding and window frame. I coudl probably go back and put some kind of adhesive to glue it flush
    Bottom line is I can't recommend that these are a good fit. Quality seems ok, but they just don't fit like the OEM That coupled with an unknown lifespan makes them sketchy.
    The OEM are probably close to 45 each ( driver door is somewhat cheaper ) and this set was $64. If I could have found genuine OEM for $25 each I would have gone that way. My prius is getting old and kind of a pig, so I would probably do this again given my situation.
  15. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    I used black silicone caulk for roofing. Mask off your windows. Apply silicone bead to worn out trim. Wet your finger or use and ice cube to smooth it out. Let dry 24 hours. It’s been 2 years and still good in Colorado winters !
  16. Ed Ferris
    Ed Ferris Junior Member
    Richmond, Indiana
    What's the link (or vendor) for these? I only found a set for $150 or so.
    My DIY fix was black duct tape, folded over one-third. Doesn't work well.
  17. Frontporch
    536
    123
    Nj
  18. Ed Ferris
    Richmond, Indiana
    Thanks. I'll see how the $150 set fits.
  19. Frontporch
    536
    123
    Nj
    Hmmm. You asked for the link and then decided to go another way. I would think for $150 you might be close to buying oem from an online dealer that actually offers a discount. eBay has parts that look illegitimate like oem but buyer beware. It’s pretty easy to put labels on plastic bags
    jerrymildred likes this.
  20. Ed Ferris
    Richmond, Indiana
    GENUINE OEM TOYOTA 2004-2009 PRIUS FRONT & REAR DOORS BELT MOULDINGS SET OF 4 | eBay
    Got the $150 (after tax) set. Delivered third business day, and they let me cancel my original order for two sets of two and get one set of four instead (for a lower price). Came in bags with OEM stickers and part numbers and fit exactly.
    The installation does not require loosening the door panel. I ran the windows down but that is probably not necessary. After pushing in and up with a screwdriver on the clip or clips (located by comparison with the new molding), I pulled the old molding out toward the rear or, when there was too much sticky buildup on the inside of the molding to let it move, broke off the outside by pulling out from the section with the released clip. One broken off inner strip fell inside the door, but it caused no problems (yet, anyway). The new moldings click into place by pressing them down, making sure you've got the inside lip inside the door and the short length that goes behind the front mirror is pushed forward far enough. Washed and rinsed the car and was glad to see the water running off the molding lips.
