Window doesn't go all the way down.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by XavierKing, Apr 17, 2015.
  1. XavierKing
    XavierKing Junior Member
    Raleigh, NC
    Greetings, all!
    I recently noticed that one of my windows doesn't go all the way down when I use the switch. I try auto down as well as holding the switch down until the window reaches the bottom, but no matter what, the window won't go down as far as the others.
    I was wondering if there was some sort of calibration that needed to be done. Thank you for your input.
    52,719
    sounds like you need to pull the door panel and see if something slipped or broke.
  3. XavierKing
    Raleigh, NC
    Shoot... that doesn't sound fun..
    52,719
    agreed. i'd live with it, if it was me.:cool:
  5. JC91006
    16,926
    8,637
    I'd leave it if it were one of my back windows. I rarely open those anyways....
  6. Former Member 68813
    3,524
    983
    US
    i had that in a corolla. it was covered by the 36000 warranty. no idea what the problem was and how it was fixed.
  7. XavierKing
    Raleigh, NC
    Yup... My thoughts exactly. It's barely but a quarter inch from opening all the way and it operates flawlessly otherwise. I think I will definitely not worry about it.. I was just hoping I could calibrate it through some button press or something. Sounds like it may be a hardware issue! Thanks, all!!
  8. Yakoma
    Yakoma Active Member
    470
    125
    sss
    I have a 2008 Gen 2, not a Gen 3, which has an initialization procedure that can be done when the 12V is disconnected (works the same way on my son's 2007 Scion).
    Open the window halfway. Fully close the window by holding the switch at least 3 seconds after it closes. That should initialize it.
    I think this is only for the driver's door on the Prius. Works for both sides and the moonroof on the Scion.
    If that doesn't work, I guess you'll have to remove the door panel and investigate.
    Bob Hahn likes this.
