Window jam protection?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Frederickdawg, May 14, 2016.
  1. Frederickdawg
    Frederickdawg Active Member
    596
    337
    Florida Unfortunately
    Don't ask , but whilst the doors are open I was cleaning the window top edges. Glass was halfway down the door , pressed the driver power window roll up button and by God the glass wouldn't stop even when I applied excessive pressure in an attempt to prevent it going up. Obviously didn't want to damage the motor but was under the impression that pressure would activate the pinch sensors and wind glass back down?
    LG-H901 ?
    Marie_Mtl and ETP like this.
  2. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Page 199 of the user's manual says there is a pinch protection ("jam" and "catch" so called) for when something gets stuck either opening or closing the window.
    ETP likes this.
  3. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,803
    1,170
    Auburdale FL
    Napkin is best for jam protection. Just wipe it off.:LOL:
    Put a steak in it.
    #3 ETP, May 14, 2016
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I don't think the OP is denying that it is suppose to have it.
    I think what he's saying is that his doesn't appear to be working.
    If it isn't working, I'm not exactly sure how one could most safely go about testing it. But from a safety standpoint, making sure it is working IS important. Since the OP's vehicle appears to be a brand new one? I might just mention it to the dealership repair department and let them take responsibility for testing and repair if necessary. If they say it's working? I'd want them to show me how they tested it, and SEE it work.
    Frederickdawg likes this.
  5. Frederickdawg
    596
    337
    That's exactly what I was trying to say , thanks.
    Maybe it had something to do with the doors being open when trying that "test"? Or maybe I kept my finger on the button and shouldn't have . will run some more tests. Lol - will try and not use the mother in law's neck as object.
    LG-H901 ?
    Weasle543 likes this.
  6. pakitt
    2,173
    1,313
    Colorado
    A wood stick will do for testing, and yes, it should work even if you keep the finger on the switch. Otherwise how can Brandon try to kill his annoying sister Brenda? :D
  7. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    I would roll up a hand towel and use that; less potential for damage if it is faulty.
    pakitt likes this.
  8. pakitt
    2,173
    1,313
    Colorado
    Even a better method.
    ETP likes this.
  9. Frederickdawg
    596
    337
    Rag trick worked with door closed.
    LG-H901 ?
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It only works on Auto AFAIK, I believe if you hold the switch down you override it.
    ETP and Frederickdawg like this.
  11. ETP
    2,803
    1,170
    Auburdale FL
    So you can execute a sleeping passenger.Think I suggested using a napkin to wipe the jam off. Work with me folks:ROFLMAO: BTW, was driving my first new car at officer training and my Italian friend had fallen asleep with his head out the window. I was playing with he window switches and rolled up the widow with his head in it. He was not happy.
    kithmo likes this.
