Window Trim?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by KitsuneVoss, Jan 21, 2024.
  1. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    There are what looks like black plastic pieces of trim around my windows.
    When I bought my car, the one above the passenger window was missing.
    I had to go up to New Hampshire for a funeral and just came back.
    Went through a car wash to get the salt out and lost another piece of trim afterwards.
    Where can I get replacements and what are they called?
  2. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    You should be able to get replacements from an online dealer like Olathe Toyota in KS.
    Here are the part numbers for all 4 doors:
    68171-47030 Inner RH Front Door Glass Weatherstrip
    68172-47030 Inner LH Front Door Glass Weatherstrip
    68173-47030 Inner RH Rear Door Glass Weatherstrip
    68174-47030 Inner LH Rear Door Glass Weatherstrip
    The fronts are around $48.75 each and the rears are around $38 each.
    donbright likes this.
  3. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I found a part
    7575647010
    But that is for the driver's side. Not sure what the part number is for the passenger side?
    Is above the door just tape?
  4. dolj
    dolj Senior Member
    8,652
    4,403
    So you're talking about the Rear RH Moulding of the Front Door Window Frame, then and not the weather strip?
    The moulding on the rear of the front RH (US passenger) window frame is 75756-47010 which you quoted above. The one for driver's side (LH) is 75755-47010
  5. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I think the parts I need are
    75762-47010
    75921-47011
    Do those look like the ones
  6. dolj
    dolj Senior Member
    8,652
    4,403
    If you're after the vertical trim for the rear door that goes on the front of the window frame, then yes.
    Looking back over your post, you don't actually say whether you're talking about the front or rear door, only that it is on the RH (US passenger) side.
    As you're the person right there at the car and I'm not, you're the only one who can decide which part is the right one.
  7. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I can send pictures but right now more concerned with this Prius just hit a deer.
    My roommate's car hit a deer in November and then two months later I hit one.
    We were 30 miles away from reach other so not the same "family."
  8. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Here is a picture to show what I am trying to find. Since things are now only at a dull roar, I can take a few minutes to do this
