Windows freeze closed
Discussion in 'Newbie Forum' started by DuaneHebert, Jan 3, 2013.
  1. DuaneHebert
    DuaneHebert Junior Member
    26
    Montreal
    I have a 2012 Prius and live in Montreal. When the temperature gets cold (-20C or so) the windows won't go down. There is no ice visible about the frame so I assume it's something inside the door frame.. Seems unusual and not something that I've noticed on other cars here. Anyone else see this?
  2. mikefocke
    4,072
    1,857
    Sanford, NC
    I've seen cars (non-Toyotas) where the windows would only work after the car interior was warm. I just assumed it was either water seeping down into the mechanism and freezing or grease in the mechanism freezing. Ask a dealer.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I have not had any problems down to -20F (-28.8C), but then it is quite dry up here.
  4. El Dobro
    El Dobro A Member
    7,102
    3,282
    It could be condensation freezing in the window channels.
  5. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    This is normal across all cars, in my experience.
    It can be mitigated a little by spraying the window channels with silicone spray.
  6. DuaneHebert
    26
    Montreal
    That's probably it. Like Spiderman says it doesn't happen to him but it's dry where he is. It's not dry here in Montreal. Funny though, my last car was a Focus and it didn't do this but my wife had a Corrola and it did. Now she has an Accord and it doesn't.
    Anyway, no big deal, it's only cold here 8 months out of the year <g>
  7. El Dobro
    El Dobro A Member
    7,102
    3,282
    When you get the windows warm and down, try spraying the channels with WD40.
