Windows not rolling up/down at all.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Slavatheshrimp, Sep 26, 2018.
  1. Slavatheshrimp
    116
    73
    Mather
    My buddy has a 3rd gen prius that he recently purchased off an insurance auction and the windows aren't working at all.
    I told him to disconnect the 12 volt and reset the hybrid switch, check the fuses. Everything seems to check out. No solution...
    What else should we test out?
  2. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Connect techstream and see if the switches are working before ripping things apart.
    Raytheeagle likes this.
  3. JC91006
    16,673
    8,518
    Use the switches on the door and see if they work. Don't rely on the driver's switches
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Nice suggestion my dude:D:p:LOL::ROFLMAO:.
    bisco and Grit like this.
  5. Slavatheshrimp
    116
    73
    Mather
    NONE of the switches are working - should of mentioned that.
  6. bisco
    51,154
    sounds like a harness coupling got disconnected somewhere
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Never mind. I retract my question. Already answered.
  8. ChapmanF
    17,345
    grid had a good suggestion. Use Techstream and watch in the active data list to see the status of the switches while you push them up and down. You'll find out if the windows aren't working because the switch signals aren't reaching the ECU, or the signals are getting there but power's not getting to the motors.
    -Chap
    jerrymildred likes this.
  9. Slavatheshrimp
    116
    73
    Mather
    Update: My buddy found that the driver side motor was fried so he replaced some components and its now working. Thanks for all the suggestions!
  10. bisco
    51,154
    so, he doesn't care about the other windows?(n)
    Raytheeagle and Grit like this.
  11. Slavatheshrimp
    116
    73
    Mather
    From what he said - fixing/replacing the main motor got the rest of them to work.
  12. bisco
    51,154
    huh, must be wired in series:cool:
  13. Randy Rued
    Randy Rued Junior Member
    Santa Rosa
    My mechanic said it would cost $800.00 to fix the front passenger window to go up and down. Is there any other way to replace or fix this? I have a 2010 Prius generation 3. Thanks.
  14. bisco
    51,154
    find a better mechanic, who will install a salvage motor. or maybe it's a loose wire inside the door.
    it is not particular to prius, and something anyone should be able to do.
  15. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Whose your mechanic?
    Are you mechanically inclined?
  16. ASRDogman
    ASRDogman Senior Member
    7,241
    3,780
    MANY youtube video's of how to replace the regulator, and/or motor.
    Just do a search and watch at least 5 of them.
  17. Randy Rued
    Santa Rosa
    Sorry I am not mechanically inclined. My mechanic thinks the motor is bad. To replace is $800.00
  18. bisco
    51,154
    ask her to install an eBay/salvage motor
  19. bisco
    51,154
    i paid $800. back in the 90's for our chrysler minivan drivers door window motor
  20. ASRDogman
    7,241
    3,780
    $800?????? SERIOUSLY? 1 hour labor, 2 TOPS, at $100 and hour labor rate? So $200. Motor? $100? $200 from Toyota.
    Okay, so at the EXTREME MOSTEST, $400, But in the real world, $200 TOPS!
    Time to look at other places.
