Window's opening
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Azmi, Sep 29, 2020.
  1. Azmi
    Azmi New Member
    Jordan
    how to add windows opening feature on Prius 2016 or check if it's available already
  2. Tideland Prius
    16,680
    You have to go to the dealer to get it changed.
    There’s two ways to open - press and hold the UNLOCK button on the fob or take the small key out, insert it in the driver’s door and twist and hold (one way is unlock and open windows, the other way is to locks and close the windows)
    alanclarkeau likes this.
  3. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    I used Carista on Android with an OBDII dongle to do this.
    kithmo, jerrymildred and alanclarkeau like this.
  4. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    If do this will it open using the smart key?
  5. Tideland Prius
    16,680
    Using the key fob, yes. Open only. To close, you have to use the physical key to slot into the drivers door.
    Now, it’s a separate option so you have to tell them you want the “key in door operation” enabled as well.
  6. PaulMalasankas
    PaulMalasankas New Member
    Ruskin Fl
    2018 Prius
    Are you based in the US? I really want this feature but DONT want to go to the Stealership.
