Windows Update and boy do they want you to use Edge
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Jun 16, 2020.
  1. Mendel Leisk
    41,350
    I usually shut it down overnight, but it'll also spend 80% of the day in sleep mode. Well it used to. I've tried shutting down service MoUSO....exe. This seems to be the culprit? Check it is indeed off. Half an hour later, computer will be still awake, check again: it's baaack.
  2. Mark57
    2,945
    2,740
    OK
    In powershell try
    powercfg -h off then enter
    This will disable hibernate mode, and will remove hiberfil.sys which may be corrupted causing the long shutdown. This will also disable the fast boot mode.
    Power off
    Now enable again by running
    powercfg -h on then enter
    Hibernate and fast boot will be enabled again.
    Power off
    Restart and test hibernate and see if your issue is fixed.
    Good luck.
  3. Mendel Leisk
    41,350
    Followed your instructions to a T, did the CMD prompts as administrator, cut and pasted the command and switches, did all the shut downs. No soap. But thanks, worth a try. (y)
    One of the links I posted has last entry Aug 06; this is really a current problem, likely due to buggy update.
    Mark57 likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Ready for a Mac yet? I only shut down when a major update requires a reboot. You already upgraded to a Prius. Why not upgrade the computer, too? :D :whistle:
  5. Prius Maximus
    Prius Maximus Senior Member
    955
    810
    Northeastern IL
    I've been using a mac at work for 18 years. There isn't a day that goes by that I don't hate that mac even more than I hated it the day before.
    hill and Mark57 like this.
  6. Prodigyplace
    12,531
    11,757
    Central Virginia
    Not on Windows 10 Home, even with an Admin powershell.
    I notice it is marker NonRemoveable True :mad:
    What is the magic incantation to remove Cortana?
  7. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Just got a used Dell laptop from eBay with Windows 10 Pro OS. I needed it to take on a trip. Reset the system and download the Brave browser to set it as a default. Edge will stay dormant never to be opened again. Just in case I need other synched credentials, I also downloaded and installed FireFox and Chrome, but they will also stay dormant on this laptop for the most part.
    #27 Salamander_King, Aug 9, 2020
  8. Mendel Leisk
    41,350
    Did another Windows update, and the computer's going into sleep mode properly now.
  9. Mark57
    2,945
    2,740
    OK
    Just in time for patch Tuesday . . . . today. :D
  10. Leadfoot J. McCoalroller
    8,072
    7,553
    Pennsylvania
    2018 Prius c
    I dig that one too. Seems to be the same idea as Aviator, but I hope they can keep it together longer!
    Salamander_King likes this.
  11. Salamander_King
    11,016
    8,948
    New England
    I've been using Brave as a default browser on my Android phone for a while. I tried it on the Chromebook, but due to the implementation of the Chrome browser as an integral part of the OS, using any other browser as a default is not possible. It is a Chromium-based browser. I use to use Chromium on all of Linux boxes, so I know it is very stable and super fast. But what I really like about the Brave is the privacy protection and security measures. Paired with DuckDuckGo as a search engine and VPN connections, I have much less fear of snooping eyes than any other current browsers out there.
  12. Mendel Leisk
    41,350
    Could be. Short-lived reprieve, now it's not going to sleep again. :confused:
    fuzzy1, Mark57 and Salamander_King like this.
  13. Mark57
    2,945
    2,740
    OK
    Sorry, I'm not surprised. I finally disabled that feature and fast boot on my W10 laptop. Being an IT guy, shutting down was my normal mode anyway.
  14. Mendel Leisk
    41,350
    Another update* (aug 12), and it is going to sleep again. :ROFLMAO:
    * This one I think:
    (No mention of "sleep" in the above.)
    Ok, that's weird, can't post a link. A search string:
    August 11, 2020-KB4566782 (OS Build 19041.450)
    Mark57 likes this.
