Windshield question
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Mrpcar, Oct 27, 2015.
  1. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    I need to replace the windshild on my 2014 prius plugin, this is a base model I don't have HUD.
    I am finding out that the plug in windshield is different from the regular prius. Why is this?
    52,792
    no idea, what did you find, different part numbers?
  3. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    It's the same windshield.
  4. mrbigh
    3,686
    699
    Long Island, NY
    There is not physical difference at all. What's the source of your info?
  5. Mrpcar
    542
    253
    Chino Hills, CA
    Safelite If you go into their web site for the online quote you will see two different prices. However I finally was able to get them to pull both windshields and they said they are the same. So I ended up with the standard Prius one, less cost. Thanks
  6. bisco
    52,792
    well done! how much did they get? how much is the hud?
    how can you tell the difference looking at a hud windshield?
  7. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    It doesn't seem like the HUD would require a different windshield. I do remember the 2010-2011 Plug-in coming with an acoustic interlayer, sound absorbing windshield.
  8. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    AFAIK, the HUD windshield has an area on it with a special coating on it to make the display easier to see. Kind of like a two way mirror coating, but not as reflective/extreme.
  9. bisco
    52,792
    2010-2011 plug in?(n)
  10. mrbigh
    3,686
    699
    Long Island, NY
    Can a lady use that section of the windshield to apply make-up too????
  11. SAronian
    334
    144
    Oakland, CA
    My mistake. should have said Gen 3 Prius. Don't know that the Prius PHV ever had an acoustic windshield.
  12. bisco
    52,792
