Windshield reflection of dashboard lights, what to do?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Toyotatrader, Feb 9, 2015.
  1. Toyotatrader
    Toyotatrader New Member
    There's an annoying reflection in the windshield of the dashboard lights at night. What have any of you done to get rid of it? I put my neck gaiter on the dash and it was great help, but not very permanent.
    The
  2. enviroprius
    enviroprius Junior Member
    91
    Sonoma, CA
    I'm curious of the responses here. I've always dimmed the dash lights but there is still a reflection. Hoping someone has a good fix.
  3. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Google dash mat and see if something like that would not work for your needs. I have one on our Honda Odyssey and it works well. I never semi-permanently attached it so that I could clean it and the dash more easily. Also using low luster vinyl protectant products can reduce/minimize glare. Our Pri is not my daily driver so I have limited night driving experience sorry.
    52,849
    there's been a lot of paperboard and duck tape solutions...
  5. Yakoma
    Yakoma Active Member
    470
    125
    sss
    I wonder if some type of semi-opaque window cling attached to the lower glass would reduce the glare.
  6. Doc Willie
    1,717
    144
    Out there, somewhere
    I put a small strip of thin black foam from a mouse pad down there, and that took care of it. Otherwise, dim the dash display. It will last longer and really does not need to be as bright as the default.
    Toyotatrader and Yakoma like this.
  7. fuzzy1
    10,706
    Are you tall? Does it go away if you slouch a bit?
    My GenIII and another brand car do the same, due to a reflection that is blocked by the top dash lip for drivers under roughly 6 feet tall. If I slouch a bit, I can eclipse it, but at that cost of increased back discomfort. The optical geometry of your GenII may not be identical.
    Some flat black fabric does a similar job for me.
  8. ozarkretiree
    ozarkretiree Member
    72
    26
    Missouri
    Four Touring
    At the risk of asking the obvious - are you using the dimmer?
  9. Toyotatrader
    I found the dimmer switch the other day. I like the black foam from a mousepad suggestion. Sounds perfect, I'd like to wear my neck gaiter again soon.
  10. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    I noticed the same on my 2008. It was a reflection from the projector window for the speedometer cluster. At my height in the seat, the reflection was right where I looked through the windshield. I inspected the area in the dark with the dash lights on one night and noticed some dust accumulated around the edges of the projector window. I was able to Q-tip some of it away and reduced the reflection somewhat, but it was still visible. Just resigned to not noticing it after a while.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Whats a neck gaiter?
  12. rifis
    rifis Junior Member
    I
  13. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    It's like a pull-over or zip-up piece of insulating fabric to cover and protect the area of chin to chest that may be exposed to inclement weather.
  14. Toyotatrader
    Just Google neck gaiter and you will get pictures. It is worn instead of a scarf around your neck for warmth. Basically a tubular shape of material that you pull over your head. Mine is currently lying flat on my dash and providing a non-reflective surface to eliminate the windshield glare from the speedometer light.
  15. Yakoma
    470
    125
    sss
    They live in Gainesville, FL...they're usually red.
    Go Dawgs!
    Toyotatrader likes this.
  16. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Never seen one before.
