Windshield replacement affect rear-view dimming?
Discussion in 'Prime Main Forum (2017-2022)' started by drager21, Mar 7, 2022.
  1. drager21
    drager21 Junior Member
    San Antonio, TX
    I had my windshield replaced on my 2017 Prime at Safelite a few weeks ago, and I dont drive at night much, but recently noticed my rear-view mirror is not dimming anymore. I know its all the same piece that they have to reattach, calibrate, etc., but I couldnt find any info that would tie the rear-view no longer dimming to uninstalling and reinstalling it on a new windshield. The green light goes on and off pushing the | and the O, but even with bright truck headlights behind me, no effect when I would turn it on and off with the lights behind me. Any ideas?
  2. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    The split in the rear hatch glass casts a shadow directly over the small square light sensor of the mirror. It was bad enough on my 2016 Prius I was glad to have a manual mirror on my '22 Prime XLE.
  3. drager21
    San Antonio, TX
    Good idea, but thats not it, did another test when shining a light directly in with the rear hatch open. :(
  4. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Have you tried covering the sensor on the back of the mirror with your finger, in broad daylight? That test should trigger the mirror to dim. If it doesn’t (and of course is “On”), then the mirror is probably malfunctioning.
    Seems you have already confirmed there is power and that is good. Perhaps try pulling the fuse for a few mins and reinsert to “reboot” the mirror and see if it makes a difference?
    Not much else to think of at this point, maybe need to see a dealer or specialist. I can’t think of any reason a windshield replacement should affect this unless it is somehow resulting in unnatural light on the rear sensor.
  5. Trollbait
    12,829
    I was thinking a wire to the mirror got strained or pulled loose during the install process.
    Sarge likes this.
  6. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Pop open the plastic cover with (see FITCAMX dash camera installation video for instructions). I’d post a link, but I’m not at home right now. As Trollbait suggests it is likely just a loose connection.
    Home now, here's a link:
    #6 pghyndman, Mar 10, 2022
  7. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    Can u share how much is the windshield replacement?
