Windshield squirters
Discussion in 'Gen 2 Prius Main Forum' started by Tony714, Mar 1, 2021.
Tags:
  1. Tony714
    Tony714 Member
    103
    17
    Orange County
    Hey Prius Peeps,
    I bought an ‘08 recently and noticed the windshield squirters squirt in a very tight pattern. Is there a way to adjust them? Every other car I had allowed for adjustments.
    And the stream is very weak. What can I do to fix that?
  2. PriusCamper
    PriusCamper Senior Member
    11,117
    4,524
    Pacific Northwest, USA
    Remove them or more difficult leave them in place and clean 'em out... A needle has worked for me before... If that doesn't work we can talk other options.
  3. pasadena_commut
    pasadena_commut Senior Member
    1,504
    456
    Southern California
    There is a diagram of the correct pattern in this thread:
    Normal windshield washer nozzle pattern? | PriusChat
    Toyota sells a special tool to adjust the nozzle direction. I made do with two stout pins (fairly long ones which my wife used in quilting) clamped between the jaws of a pair of needle noise pliers. This was one of those adjust, overshoot, adjust the other way, overshoot again sorts of scenarios. The little nozzles stick in a given position and then jump once they break free, so it is hard to get the angle just right.
    As for the weak stream (he says, barely avoiding using a prostate joke) if a fine pin does not do the trick remove the washer heads and soak them in vinegar. Or once they are off the car attach a tube to them and push vinegar through with a pump, if you have a syringe that will work.
    SFO likes this.
  4. ChapmanF
    15,739
    Thank heavens you did. My last dose of apophasis was over a month ago.
  5. Tony714
    Tony714 Member
    103
    17
    Orange County
    Thanks everyone for the replies. I was Traveling for a bit for work so excuse the late response.
