Windshield still streaking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FishHawk, Oct 15, 2006.
  1. Frank Hudon
    Frank Hudon Senior Member
    4,147
    be advised that some people have found that rubbing alcohol removes the paint on most of the trim inside of the Prius.
  2. Actual Mileage
    153
    Portland. Maine
    <div class='quotetop'>QUOTE(onerpm @ Oct 23 2006, 03:47 PM) [snapback]336987[/snapback]</div>
    Second!
    (Hermes works much better than Gucci.)
  3. xbdude
    xbdude opticat
    168
    North Central Florida
    I can't understand what is causing the INSIDE of my windshield to get streaky. I don't smoke, nor has anyone ever smoked in the car. It is garaged. I cleaned the inside of the windshield two days ago with "Cinch" and a soft rag and it looked great. Today, it's all "foggy" again and it doesn't go away unless it is wiped off. Weird.
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I get the same thing. Could it be the plastic or carpeting emanating gasses?
  5. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(xbdude @ Oct 31 2006, 03:14 PM) [snapback]341596[/snapback]</div>
    some times a very slow leak in the heater core will put antifreeze mist on the windshield. Also if you have a plugged A/C drain and run the Climate system on Auto the moisture in the evaporator will go on the windshield with what ever is in the housing. If possible to leave a window down an inch or two when your parked in the garage might help as well.
