Windshield washer arm adjusment possible?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bmparent, Jun 8, 2021.
  1. bmparent
    bmparent Member
    159
    65
    barre ma
    So one of my windshield washer arms is making a lot of noise from hitting the bottom of the window. It's the one on the passenger side, with the large base. When not in use it seems to be resting too far down, too close to the bottom of the window all the way across. Is there some way to adjust this? I've double check and the wiper blade is attached properly.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,027
    1,957
    NJ-USA
    Yes, you can adjust the wiper arm position. There are two links and pivots for the passenger side arm. The left pivot drives the arm, while the right one just moves freely. Have the wipers in the parked position.
    What you want to do is to loosen the nut on the left pivot a few turns, then grab the link near where it connects to the big arm and gently push and pull straight up and down perpendicular to the windshield until the link comes loose from the pivot. Move the wiper arm so the blade is about an inch from the trim at the bottom of the windshield. Put the nut back and snug it down- torque spec is 15 ft/lbs.
    SFO likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Is this an OEM blade assembly ?
    If not, that might be part of the problem.
  4. bmparent
    bmparent Member
    159
    65
    barre ma
    As far as I know, the wiper arm has never been replaced so it's probably original.
  5. bmparent
    bmparent Member
    159
    65
    barre ma
    That's perfect, thanks. Sounds simple enough!
  6. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    You can remove the nut and take out the wiper, and insert it a little more up...
    The pictures attached shows the position of arm when you make adjustments...
    bmparent likes this.
  7. sam spade 2
    7,035
    2,801
    2017 Prius c
    Not talking about the arm.
    The assembly that holds the rubber blade.
    If you get aftermarket replacements, you usually get the whole blade assembly and not just the rubber refill.
    Those are sometimes a slightly different size and can act differently........including making the action on the glass different.
  8. mr_guy_mann
    4,027
    1,957
    NJ-USA
    True enough. Some replacement blades are centered on the arm while others can be offset above or below the centerline.
  9. bmparent
    bmparent Member
    159
    65
    barre ma
    Ah, I see. I didn't know that. I don't know what brand I last bought but I'll look into this and maybe start with buying new blades first.
  10. bmparent
    bmparent Member
    159
    65
    barre ma
    Happy to say I finally got around to doing the adjustment today, it was really a piece if cake. I'd forgotten what silent windshield washers are like, what a relief! Thanks for your help folks.
