Windshield Washer Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by john_dough, Nov 11, 2011.
  1. john_dough
    john_dough New Member
    75
    Front washer not working--rear washer works OK--reservoir full. I can't determine if front and back each have their own pump or where they might be located--suspect under the reservoir, but haven't taken that out yet. I guess it could be a fuse. Can anyone help with ideas on this problem? (I've read old posts to no avail). Thanks.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Have you tried running a small pin in to the hole on the washer spray nozzle to make sure that the nozzles are not plugged?
