Windshield washer tank level sensor location
Discussion in 'Gen 2 Prius Technical Discussion' started by Dion Kraft, Mar 1, 2025.
  1. Dion Kraft
    Dion Kraft Member
    305
    92
    Washington, UT
    My wifes 2009 Prius has the windshield washer empty icon displays but the tank is full of fluid. Rear wiper sprays but the fronts do not. I see only wires leading to the tank with the dual spray motos but where is the LEVEL SENSOR located. Suppose to be in the tank but I don't see it on the vidoes of replacing the tank. I think my problem is the sensor is bad but it does not stop the washer fluid from spraying so that means one tank motor is bad or no voltage to it.
  2. Tombukt2
    Tombukt2 Senior Member
    13,806
    2,504
    Durham NC
    I'll have to go out and look for the level sensor It should be similar to the one that's in the brake reservoir but obviously in the washer fluid tank I haven't had to replace one in this generation type 2 car yet The pump motors go bad all the time and all the washer fluid pump manufacturers make a motor that can fit in either of the two places on the washer jug Don't take it off until you have a replacement in hand once you pull it out you got to have something to put back or you're not going to have any washer fluid in the jug I guess you can shove the old motor back in.
  3. Dion Kraft
    Dion Kraft Member
    305
    92
    Washington, UT
    I looked at all these Utube videos on tank removal and installs but all of them show the twin washer motors and unplug them...no sensor shown.....I guess I will buy two motors (because its the wife !) or whole tank and 2 motor setup to do this only once LOL!
    Thanks for the quick response...
  4. Tombukt2
    13,806
    2,504
    Durham NC
    I mean somebody here should know this I don't have the factory manual available to quickly open and see but either there's something that floats in the tank that goes up and down as you feel it around that area where you're filling or something along those lines or it would be a separate things screwed right into the side about where it would go off when it got below that it would turn on a light set off an alarm whatever it does I didn't even know it had such a thing not to empty mine and see what happens if it's the kind that's in the tank maybe there's a bunch of crap in the tank take the tank out clean it out with some super clean that purple stuff whatever and then you'll be able to see inside of it better and see if there's someone you flip it over if there's something rattling around maybe it's just stuck
  5. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Can you take a photo of what the low washer fluid indicator looks like on your wife's car?
  6. Dion Kraft
    Dion Kraft Member
    305
    92
    Washington, UT
    Alright ya'all....mystery solved and APOLOGIES on this wild goose chase......The indicator on the dash is NOT the LOW washer fluid icon but the Windshield defroster icon displaying that it is ON. I took my wifes word for it and did not validate her claim as she told me the windshield washers (Fronts) did not work either....threw me off even though I am a retired prof mechanic with 50 years wrenching in the fleet repair profession...2004-2009 Prius does not have a LOW Washer fluid sensor. I have the 04 and the wifes the 09. I ordered an Amazon washer pump so that should take care of the problemo....I thank everyone who participated !
    I took my wifes word that the icon displayed was for LOW Washer fluid as the front washer nozzles did not spray but the rears worked. I thought I would be slick and swap out the plugs on the washer pumps but they are indexed so you can't do that to test if the rears would power the fronts.. Anyways both plugs show 12 volts+..so I assume the front pump has died so I ordered another from Amazon...two day shipping!!
    Thanks for replying and helping me out but I screwed up royally in not investigating the ICON symbol on the dash as my wifey told me the washer fluid icon is on and the front windshield is not getting sprayed....I took her word and proceeded with bad information.
    The ICON was the Defroster ON indicator. I tested voltage to both pumps and they have 12v so I ordered one pump thru Amazon and should arrive today. 2004-2009 have no washer Indicator as their is no sensor in the tank! Thanks again for help irregardless!
    #6 Dion Kraft, Mar 2, 2025
    Brian1954 and Mendel Leisk like this.
  7. Dion Kraft
    Dion Kraft Member
    305
    92
    Washington, UT
    Just a few technical details I found out with washers pumps on the 2004-2009 Prius. When opening the hood and you are in front of the vehicle looking left....the pump nearest the right front fender is for the rear and next to it toward the engine is the front.
    The plug ins are indexed so you can't mixed them up. On mine the rears worked so I thought I would plug the rear plug into the front motor but you can't....had to resort to my DVOM to check for voltage. When ordering pumps the most common one is the front pump plug in configuration.
    Prices for the front pump is $8 and up - part no: 85330-60190
    Price for the rear pump is: $24 and up to hundreads new or used. - part no. 85330-60180
    Trico sells one rear pump 11-617 for $24 - best deal I found for rear pump.
    #7 Dion Kraft, Mar 2, 2025
  8. Tombukt2
    13,806
    2,504
    Durham NC
    Yes I've never had to go buy a pump there's a bunch of them you can get I just usually pop them out of other vehicles when I'm at the junkyard they'll just let you have those or charge you a dollar or something silly If you're jug isn't broken and you don't need it may usually won't bother you for the pumps If you bring the whole jug up you're paying 50 bucks for it
  9. dolj
    dolj Senior Member
    8,633
    4,386
    Wellington, New Zealand
    Because of what you said following this statement, this is just confusing. You maybe could have said, "When opening the hood and you are in front of the vehicle look left towards the right-hand side of the vehicle, ..."
    Just to clarify for others following, – just as it is with the human body, planes, boats, and ships,– the left and right of a car are always referenced as you look forwards from the driver's seat or standing at the rear of the car looking forwards.
    So, the rear pump is on the right side of the reservoir (nearest the RF fender), and the front pump is on the left (nearer the engine).
  10. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    I know that there is no such sensor, that's why I asked the question.
    It is possible that there is a mix-up, but it is not a big deal.
    It would be much more serious if such an icon was mistaken for a low washer fluid level.
    dolj likes this.
  11. Dion Kraft
    Dion Kraft Member
    305
    92
    Washington, UT
    Replaced the front windshield washer motor in the tank today and all is well now
    Thanks for everyone who participated and helped out !
    Brian1954 likes this.
