Windshield Wiper fluid dropping on its own
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by robsnyder20, Jun 8, 2018.
  1. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    toyota.jpg Hi all, Just coming up on my 36k mile warranty and mentioned to toyota on my last service visit about the windshield wiper fluid is never filled after it is serviced. Sure enough I got back home and found nothing showing. Bought a bottle and refilled it and took maybe 16 oz to top off. Waited a day and then filled up a few oz because it went down at least two inches (never used any at any time), then popped it back open and refilled and it dropped again a couple inches the next day (repeat same scenerio over several days). So either I'm thinking I have a leak or it spills if it is filled to the tippy top. Anyone else notice anything wierd like this? On my last toyota I used to keep it filled right to the top and it would be like that till I used any. Thanks for any suggestions or comments.
    52,878
    nothing under the car? are you using it at all?
  3. robsnyder20
    378
    302
    SW Florida USA
    Nothing that I noticed (running the AC always this time of year in Florida) and have not been using any for sure, been extra careful.
    52,878
    so it has to be leaking at the tank. feel around underneath.
  5. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    My 2016 Three does that too. No worries, Mate! Just another Prius oddity! :cool:
  6. bisco
    52,878
    welcome to priuschat! that is an oddity, but must have a cause.
    another idea would be not to refill and see if it keeps dropping.
    jerrymildred and Starship16 like this.
  7. Starship16
    1,348
    1,455
    Beach Christmas
    Like Rob, I do not see any leakage under the car. Maybe an air bubble or something in the fill tube? But I never seem to be without fluid, when needed. A couple minor oddities, but my '16 Three has been outstanding and excellent so far. Currently at 20,000 miles. Average 56 mpg in stop & go city driving. This Prius has exceeded my expectations! Very happy.
  8. Mendel Leisk
    42,364
    Yeah, same thought here. I always speculate that the most leak prone area might be the joint between the long neck and the tank.
    alanclarkeau likes this.
  9. robsnyder20
    378
    302
    SW Florida USA
    Thanks for the input guys, I have never ever ran out of fluid and use it a lot (until I stopped using it the past couple weeks(. I was wondering if I needed to rush and demand it in to be fixed before the 36k warranty runs out. I couldn't find any fluid anywhere but it has never went dry either. I was almost thinking I might have a leak in the line going to the rear wiper maybe or something. So I am not refilling it to see if it seems to stabilize on dropping. I'll chime in later this week.
    Raytheeagle and Mendel Leisk like this.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Might be better to report it to dealer now, so good be covered of it were to fail just after warranty. (n)
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I've noticed the Gen 4 is a pain to fill, a lot of turbulence in the bottle and it froths up and takes an age to settle. There is a low fluid level warning that comes up on the MFD so it's harder to run out.
    RCO and Starship16 like this.
  12. robsnyder20
    378
    302
    SW Florida USA
    Well just to chime back, after pretty much believing there was a leak, I resisted to top off for like the 5th time and the level has stabilized at about the same as the pic. Not sure if there was air bubbles in the tank (somehow?), came out a bit when driving, or evaporation when overfilled but it has sense stabilized more than a week without dropping further. Never the less, the 36k mileage warranty is just about up and took it to my trusty mechanic to give it a once over (over the entire car) and didn't find anything. I heard other dealerships may not let you know if you have a leak or something within the warranty unless its a safety issue. Figured safe than sorry. Thanks all.
    Mendel Leisk, jerrymildred and RCO like this.
  13. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    You could use a leak detection dye if its really bothering you. Of course your squirts are going to be colored.
    RCO and krmcg like this.
  14. shrek
    shrek New Member
    24
    sc
    Mine does the same thing
