Windshield wiper replacement on the 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tlo, Mar 18, 2010.
  1. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    Rear: 85214-0E050
    Driver: 85214-68020
    Passenger: 85214-30390
    the passenger side number is wrong for 2010 prius at parts.com
    if you have model year 2010 use the model year 2011
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I just learned the same thing, I should have done a search first. The three factory refills were approximately $6, $7, $8 for a total of $21. The Toyota blade design is nice, they are the easiest inserts to change that I have ever done.
    As JD found out, the universal inserts don't work very well. The problem is that the Toyota metal splines that fit Toyota inserts are much thicker than normal insert splines and they are curved to function as springs to hold the full length of the blade against the glass. The universal insert splines are too thin and weak to function as springs and the Toyota splines won't fit in the universal insert rubber.
    jdcollins5 likes this.
  3. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    You can subscribe thru Alldatadiy.com (for all of your vehicles, if you want). There are discounts for multiple subscriptions and technical service bulletins are kept up to date as well.
    I've done this for several years and am well satisfied.
    (I'm not associated with the Alldata folks in any way).
  4. Mendel Leisk
    42,345
    Here's wiper blade replacement info:
    fopoku2k2, frodoz737 and xs650 like this.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Thanks for posting the instructions. It's really easy to do. One thing to watch out for is that you need to save the metal splines to use with the new rubber. Most blade refills include new splines, but not Toyota. Fortunately the splines look like substantial stainless steel so should last the life of the car.
  6. our1vue
    our1vue Member
    313
    58
    NY
    I replaced my wiper blades on my 2012 last week. I have a question. On the driver side, the indent to hold the rubber
    on the blade was at the top of the blade. On the passenger side, it was on the bottom. Is it suppose to be that
    way or doesn't it matter. Thanks
  7. Charlie Bravo
    Charlie Bravo Junior Member
    New Orleans
    How much does it cost to just have the Toyota dealer put on new wiper blades for me? Parts are about $22...how much is labor?
  8. R1CH13
    R1CH13 Member
    Michigan
    Is the rear wiper really important? I mean how often do you use it?
  9. Tandem Rider
    Tandem Rider Junior Member
    56
    Indianapolis, Indiana
    I paid $26 to have the driver's only replaced at the dealer.
  10. dhendriksen
    dhendriksen Junior Member
    57
    I'm glad I found this. I'm getting some pretty good streaking from the drivers side.
    DROID RAZR HD ? 2
  11. R1CH13
    R1CH13 Member
    Michigan
    $26 for the driver side is pricy. I got a 26" and 19" for $27. I went with the Rain-X Fusion just because they're similar to OEM but for a fraction of the price. They meet OEM standards
  12. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Do you guys need a tutorial on how to replace your wiper blades? its pretty easy...
  13. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    yes we do. please do one of your lovely youtube video tutorials for us
