Winter and the Prius C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by johnhlong, Oct 24, 2013.
  1. johnhlong
    johnhlong Junior Member
    89
    29
    East Carbon, Utah, USA
    I have a 2013 Prius C2 and live in Utah.
    I do not have a garage so the car will be outside all winter.
    Temperatures here will drop below freezing and sometimes below zero at night.
    There have been weeks on record when the temperature didn't even get above zero. :whistle:
    Should I be thinking about getting a battery heater and/or a block heater?
    John
  2. KYBlue
    KYBlue Active Member
    227
    111
    Block heater is awesome, for no other reason that quicker heat! I'm only in KY, its been about freezing here nightly and it makes a world of difference for the engine shutting off quicker and heat starting quicker.
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    That's up to you. The car will be fine without it, but your MPGs will take a hit and as mentioned by KYBlue, you will get heat quicker if you get one.
  4. Phil 29 Palms CA
    119
    44
    Twentynine Palms, CA.
    I live in the Mojave desert. My lowest winter temperature is about 25 degrees F. How much sq. ft. area can I block without the fear of overheating my engine and damaging it?
  5. riban
    riban Junior Member
    I would say "No" I'm in Ontario Canada and we have already experienced a few days of below zero temperatures (Celsius -5). Anyways the C showed no signs of any issues, it did take awhile to heat up so the gas engine ran a little longer than usual but with say 5-7 minutes the car was nice and warm and running as usual.
  6. RikMoore
    RikMoore Junior Member
    Royston Ga
    Any problems with your C shutting off after getting to 14mph and not apparently engaging the gas engine.
