Winter gas mix
Discussion in 'Gen 3 Prius Fuel Economy' started by HoytHoytHoyt, Sep 25, 2013.
  1. HoytHoytHoyt
    HoytHoytHoyt Junior Member
    Atlanta
    How much does the winter gasoline mix effect your gas mileage?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Since other factors, like air-density and the need for heat, also influence efficiency... who knows. Heck, even driving conditions change.
    So, we're all kind of stuck with a bad situation.
    It is fortunate that even in those conditions, Prius stills delivers better gas MPG than everything else out there.
  3. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    For that matter, what is this "Winter blend" everyone talks about. When people complain of poor mileage in the cooler months and attribute it to the winter blend, they don't explain what it is, or why it would provide less energy per volume.
    Most of us here know that cold, dense air increases aerodynamic resistance, that engines and fluids take longer to warm up, and that the vehicle cools off faster when it's cool out. Tire pressures will be reduced in cooler weather if they aren't inflated, and running defrost (AC) reduces fuel economy. I would think all of these factors would decrease fuel economy more than winter blend fuel alone.
  4. heyjack70
    heyjack70 Junior Member
    25
    More ethanol in the gasoline in the winter
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  6. bwilson4web
    16,453
    This article has a reasonable discussion of summer and winter gasoline blends: A Primer on Gasoline Blending | EPRINC
    When I was doing gasoline studies many years ago I could see butane come out of solution in a graduated cylinder. Butane is used in winter gas when the cooler temperatures won't cause it to evaporate.
  7. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Hmm what did you see? I do not think butane would come out of solution, but you might see vapors?
  8. bwilson4web
    16,453
    Bubbles and a small loss of volume after shaking.
  9. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    OK I agree you may well observe that. Best you can do is refrigerate the sample to minimize vapor losses.
  10. bwilson4web
    16,453
    It was as if the gasoline sample had become a petroleum 'soda water.' I could see the small bubbles form in the middle of the column and grow as they floated to the top. After vigorous shaking, the bubble formation stopped.
    I wanted to find a non-combustion way to evaluate the energy content of a gasoline sample and was thinking the density of might give a correlation. My thought was the length of the molecular chains might provide a density gradient and provide a correlation . . . no luck. Organic chemistry does not reveal its secrets that easily.
    My thinking is a small, single burner, camp stove might provide a way to burn a known sample to heat or boil a known quantity of water. A pressed, metal-matrix might hold the sample; accurate scale for before and after weight and; a water container with multiple bends to transfer the heat. If sized so the water boils, a before and after weight would give a metric of how much energy was captured from burning the sample . . . hopefully with enough accuracy to determine relative energy content. But there is this 'open flame' issue and gasoline is not forgiving.
  11. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    One would think if we had the in-the-tank gaso density we could correlate to energy content pretty well. Problem is we don't have it except on a lab study.
