Winter heating up before work
Discussion in 'Gen 3 Prius Main Forum' started by drmax, Jan 5, 2016.
  1. drmax
    drmax Junior Member
    42
    how can I unsure someone won't drive off with car when I start up to warm it? I mean I can't lock the door with it running. Not going to install a remote start (if that's even work) Wish it would not drive when put into gear to ward off thief, without key fob. Is there a solution? 2015 regular Prius.
  2. Drewintoledo
    Drewintoledo Junior Member
    49
    Ohio
    2015 Prius v wagon
    52,849
    lock it with the mechanical key in the fob, take the fob with you. test it by leaving the fob in the house and gripping the handle to make sure it doesn't unlock.
  4. drmax
    drmax Junior Member
    42
    Uh, most likely posted in wrong thread area. I have no mechanical keys locks
  5. Mendel Leisk
    42,343
    What locale are you, where in the world?
    A couple of lateral suggestions:
    1. Is there a garage available, except filled with stuff? If you can garage store the car it really helps, if the main reason for extended warm-up is to clear frost off the windows.
    2. Look into getting the block heater.
    If you can manage the first, it completely negates the main reason for extended warm-up. If you do the second, even better.
    Merged
    Yes you do, there's a mechanical key hidden in the fob. Press little latch on side while pulling on the ring. Check Owner's Manual for more info.
    #5 Mendel Leisk, Jan 5, 2016
    Drewintoledo likes this.
  6. mrbigh
    3,686
    699
    Long Island, NY
    So far I know, all Prius FOB have a mechanical hard key concealed in the FOB.
  7. qdllc
    qdllc Senior Member
    1,377
    400
    Bah....just get the remote start. Toyota's works seamlessly, and it's a lot easier than going out, starting up, then locking the door manually to rush back inside. :p
  8. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    In my experience, the car warms up quicker if you start driving immediately. That can also give you better gas mileage.
  9. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    This has been my experience as well.
    Also make sure to block your grill with the styrofoam pipe insulator things. It really seems to help retain / maintain heat and reduce warmup times...
    But I can fully relate to how there can be brutally cold days where it's nice to get into a warmed up car.. I'd say just do it if it's that cold out...
  10. 348
    348 Junior Member
    71
    36
    Central Oregon
    image.jpeg image.jpeg Here is how I keep anyone from driving off in my Enzo while its warming up, I toss the tragically named Cinnamon in.......
  11. Drewintoledo
    49
    Ohio
    2015 Prius v wagon
    Damn! That's a HUGE tree behind your car!!
  12. Mendel Leisk
    42,343
    I bet he likes that tree. :)
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I don't think leaving a vehicle running unattended is ever really a very good idea.
    I vote for just get in it and drive.
    If you don't have a remote start installed, that means you have to get up and go get in it to start it anyway. At that point? Cold or not, why not just start driving?
    Being cold while going out to the vehicle to start it. Being cold while walking back. The advantage, if any, seems incredibly negligible.
  14. Mendel Leisk
    42,343
    There's a dismaying number of folks with a car sitting in a driveway or on the street, and a garage full of junk. Getting the junk out and the car in deals with the main excuse: iced windshields.
    Redpoint5 and Okinawa like this.
  15. BZzap!
    BZzap! Senior Member
    1,607
    878
    If instant gratification is what you are looking for, a block heater is the answer. Warming up your car with the ICE idling will net you the poorest fuel economy on average.
  16. Mendel Leisk
    42,343
    The block heater is not quite "instant gratification", but it definitely accelerates warm up: in most scenarios it'll raise the car's engine coolant around 20C above ambient, with a couple of hours use.
  17. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Here you go:
  18. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    ^^^^there you go. (y)
  19. 348
    348 Junior Member
    71
    36
    Central Oregon
    We both stop to pee there on the way to the coast for fishing charters, usually passing thru 'round 0430. It's in a Redwood grove on the Smith River.
  20. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
    I warm up the car until the engine shuts off sitting in it...unless I have to shovel, brush and scrape. Then it definitely feels warmer inside.
