Winter heating up before work
Discussion in 'Gen 3 Prius Main Forum' started by drmax, Jan 5, 2016.
  1. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Are Prius ever stolen?
  2. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
  3. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Well if one is say running and locked via the window trick or with the key from the fob then someone would have to slim Jim or break a window to get in the car and yes then it could be stolen BUT only until the veh was shut off. Minus the key fob the veh cannot be restarted. So in essence it would be dead in the water at that point. FYI.
  4. MattNiem
    MattNiem Junior Member
    52
    Finland
    How does automatic climate control work in Prius after cold start? I have problem with it in Lexus CT, fan won't run at all and I have to manually turn it on to avoid frosting on windows when it's cold outside.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    The auto setting waits for the engine to warm before blowing. DW keeps complaining about the defogger button that it doesn't work. I keep telling her would you rather cold air be blasted in your face that may fog up the windows more or wait for the HVAC to condition the air a little more before it starts. Wait a few seconds.
  6. MattNiem
    52
    Finland
    I've waited few minutes, and I have to turn it on to see something :) Temperatures have been -15 to -30 celsius.
  7. bisco
    52,849
    there has been a report that a 2015 prius does not have a mechanical key.
  8. breakfast
    breakfast Active Member
    266
    199
    2015 definitely has the same mechanical key arrangement as the rest of the 3rd gens - I own one.
    As for the 2016 (Gen 4) - I have no idea.
  9. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
    Yep...2015 is the same.
  10. bisco
    52,849
    someone must have gotten gypped.
  11. bisco
    52,849
    do you have auto up? you could reach in and hit the button, then pull your arm out quickly.
  12. silversport1
    silversport1 Junior Member
    Michigan
    Last year I installed a remote car starter and cannot be more happy. It is a Viper unit that also works as remote keyless entry. It works from approx. 2-3 blocks away and is beyond perfect. The only difference between the average car and a Prius is once the car is heated up and you walk up to it to unlock the doors the car acts a little differently. Once I open the drivers side door the car shuts off, I get in and start the car again within seconds and am up and running in a warm car. I haven't really noticed a big drop in fuel economy. The Prius is always worse in the winter but getting 35-45mpg (depending on how YOU drive) when its 0-30degrees out is fine by me. Hope that helps!!!
