Winter problem
Discussion in 'Newbie Forum' started by Dan1AR, Jan 6, 2017.
  1. Dan1AR
    Dan1AR New Member
    Arkansas
    why my Prius parking brakes get stuck if temperature goes below freezing? Is it normal? Or is something failing?
    dengar100 likes this.
    52,792
    welcome!
    i think it's normal. moisture gets in there and freezes.
  3. Dan1AR
    Dan1AR New Member
    Arkansas
    I drove it for two blocks and now abs light came on and Brake light came on, , I'm scared to continue my drive
    52,792
    is the weather bad?
    how many miles on her? do you inspect and lube the caliper pins every 30,000 miles?
  5. Dan1AR
    Dan1AR New Member
    Arkansas
    Yes, roads covered in snow
  6. Mendel Leisk
    42,289
    Brake light will come on when parking brake is applied. Maybe it's stuck, at least partially applied still?
    Yeah, there is something in the Owner's Manual about the possibility of the parking brake freezing, staying applied, in very cold temperatures. FWIW I've never experienced problems llike this, but temps are never below -10C (approx 15F) here. Maybe high humidity coupled with extreme cold make it more likely? How cold is it in your region?
    Page 262 of Owner's Manual. Again, never experience problems, but I guess it can happen:
    pleasedpriusowner, RCO and bisco like this.
  7. Dan1AR
    Dan1AR New Member
    Arkansas
    Has 70k plus miles, I will check that, thanks to all ur comments. I will definitely not apply parking brake next time
  8. bisco
    52,792
    slush probably gets in there and freezes. but it's worth having a thorough brake inspection and lube if necessary.
    if it seems to roll okay in neutral, you can probably drive it.
    RCO and Montgomery like this.
  9. Bret3333
    Bret3333 New Member
    Foley Alabama
    Hey, new to the Prius and the internet. Double whammy for me, this morning my 2005 Prius started...shivering and the check engine light came on every one I talk to says not to worry "they do that" Is this true? Little help please.
  10. JC91006
    16,935
    8,646
    There's probably a misfire detected
  11. Bret3333
    Bret3333 New Member
    Foley Alabama
    Thank you, the problem started Saturday morning and stopped Sunday morning, now it's doing it again. I plan on running a diagnostic on it today, great car but way beyond my limited abilities any advice is welcome.
  12. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    What is it doing? If it's just a check engine light and you're not noticing anything else I wouldn't get yourself too worked up over it. Those lights are almost something related to emissions equipment. So get it checked but if you're not noticing anything else try not to get stressed out over it. Could be something as simple as a gas cap that isn't sealing correctly. Until you have the diagnostic code there's no way for anyone to take an educated guess at what it might be.
  13. Bret3333
    Bret3333 New Member
    Foley Alabama
    Dead on!! #4 cylinder missing simple fix thanks jc91006
    RCO likes this.
