Winter Tire advice and tips
Discussion in 'Prius v Accessories and Modifications' started by Mike James, Nov 7, 2011.
  1. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    We are running the stock 195/65/15 size for the 2010 Prius IV. See photos. Sorry about the quality, but the lighting was poor.[​IMG][​IMG]
  2. Mike James
    Mike James Camaros and Prii go figure
    142
    35
    Lincoln, NE
    Photos look great, love the 5 spoke, happy safe driving this winter. :)
  3. Mike James
    142
    35
    Lincoln, NE
    My new winter shoes
  4. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    Nice looking wheels! I'll have to give the new winter tires the "black" treatment like you did. Ours turned a milky white color after passing through the car wash.
  5. vloveride
    vloveride Junior Member
    Wisconsin
    The wheels look great Mike.
    I am mainly posting to thank you (and Toyofixer who posted the stock offset info for the v in another thread) for the information. I just installed a set of Michelin X-Ice Xi2's in 205/60-R16 on the wife's new v. I went with a set of Sport Edition F7's 16x7 with +40mm offset. They are a perfect fit.
    I also weighed the stock 16 inch wheels/tires and they are 41.4 lbs including the wheel cover. The winter setup weighed in at 40.0 lbs even. At nearly 1.5 lbs less each maybe the mileage hit won't be too bad.
    I also like the 5 spoke look.
  6. Mike James
    142
    35
    Lincoln, NE
    Silver on Silver really pops! I also really like those 5 spokes. Not too flashy and the easiest to clean :)
  7. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    We've just finished up our first tank of gas using the Michelin X-Ice2s. 50.8 MPG for this trip vs. 55.3 on the last trip with the stock Yokohama S33Ds. These figures aren't directly comparable due to a much different driving profile on the last tank that featured many short trips. The 36 miles after tanking up this afternoon came in at 60.2 MPG, which is closer to normal for that particular segment of the daily commute.
  8. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I use those same exact wheels for my snow tires. I think they look a little better on your color than my winter gray, though.
  9. skang5
    skang5 New Member
    Wilmette,IL
    tirerack now has a package for prius v
  10. skang5
    skang5 New Member
    Wilmette,IL
    can someone show me with pictures how to disable tpms on prius v? is this same as regular prius??
  11. lapdog99
    lapdog99 New Member
    Colorado
    We have new Prius V with Michelin X ice 2s. Note that Michelin is the only winter tire with a 40k mileage guarantee. The dealer sold them at the Altimax price since he didn't have the correct size in stock.
    The tires are quiet, and should give far better tread life than Blizzaks.
  12. mgarg
    mgarg New Member
    New York
    What size, type of wheel did you put the Michelin's on?
  13. mgarg
    mgarg New Member
    New York
    Mike James, Thanks for posting. I would like to order the same package from the Tirerack as you did. How Much clearance do you have between the Wheel and The Brake Calipers? Looks like the Tirerack does not recommend this Rial wheel because they are concerned about the 45 Offset being only 1-2 MM from the brake. Let us know what you see.
  14. mgarg
    mgarg New Member
    New York
    Mike, how much clearance is there between your brake caliper and the Rial rim? I want to order the same tire/wheel combo from the Tirerack but they are concerned about the 45 offset
  15. Mike James
    142
    35
    Lincoln, NE
    There is a good 7/16~1/2" between the caliper assembly and the wheel spokes on the front.
    On the rear there is more than 1 inch between the caliper assembly and the wheel spokes. The interesting thing I just noticed though is the rear discs are a good 1/2" larger diameter. I now believe a 15" rim will not fit on the rear. I will delete from first post of thread.
  16. Mike James
    142
    35
    Lincoln, NE
    Okay looks like the brake sizes are
    - Front Diameter : 10.8 in. rotor
    - Rear Diameter : 11.5 in. rotor
  17. mgarg
    mgarg New Member
    New York
    Thank you so much. I will order the same package from the Tirerack.
  18. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    We are two tanks and over 800 miles into these new Michelin X-Ice2 tires on the Gen III Prius. Our driving conditions are different due to the holidays, but it appears that the mileage penalty will be 2 MPG or less. Our trip mileage reported by the on board computer has exceeded 53 MPG while driving the "normal" profile of trips greater than ten miles. We will know for sure when normal commuting resumes in the first week of January, but for now we must conclude that there is no meaningful mileage penalty associated with these winter tires.
  19. cmjars
    cmjars New Member
    Los Angeles
    How did you reset the TPMS on your v?
    Thank you.
  20. Mike James
    142
    35
    Lincoln, NE
