Winter tires and rims
Discussion in 'Gen 4 Prius Main Forum' started by Mithrandrost, Oct 30, 2018.
  1. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
    Gen 4 owner here in Canada. Had winter tires and rims installed this week at the Toyota dealership (early to avoid the rush). I ordered a couple of week ago. Interestingly, the dealership called me when the rims came in. The parts person said he was surprised that they sent silver rims and that they could be switched for the standard black rims. I decided to keep them.
    The tires are Michelin X-Ice Xi3. I bought these based on commentary I read in Prius Chat.
  2. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
    goldfinger, krmcg and Mendel Leisk like this.
  3. Mendel Leisk
    42,348
    Oh I like those, looks much more civilized than the utilitarian black ones. It's the corolla rim, p/n 42611-02471?
    A 2" ABS end cap pushed over the center will be a loose fit, with some sort of rubber band pushed on first (say cut off an old bicycle inner tube) it will be an interference fit, and will stay on. If left exposed the hubs rust up pretty fast.
  4. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
    I would worry that with extreme cold, ice build up, etc. the end caps would loosen and eventually fall off. Have you tried this idea yourself? What was your experience?
  5. Mendel Leisk
    42,348
    They've worked for a couple of winters now. Hey, they're $2~3 apiece at Home Despot. :)
    Again, the key is to push some sort of rubber band on first, then sorta screw/tap them on. The fronts ride up slightly, on my 2010, due slight projection of the axle nut. Very slightly. Have a look at yours, being different gen. The inside diameter of the end cap is 2.375".
  6. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Could probably wrap the end caps with non-adhesive rubber electrical tape, available at hardware stores or online. Works good for other projects also, lasts a long time and you don't have to worry about adhesive not holding up in temperature extremes
  7. padroo
    padroo Senior Member
    2,763
    2,253
    I put my stock wheels back on the other day and put my American Racing wheels and tires up for the winter. I have stock Toyo's on both sets of wheels. I bet I am the only one on Prius Chat that owns 8 stock Toyo's.:)
    krmcg likes this.
  8. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
    So, I am giving it a shot. I installed them this morning. I like the way the caps look. The ones I purchased have a dome shape.
    Very tight fit (used a bicycle inner tube "gasket" as you suggested). A bit of trial and error to get them on. photostudio_1541352889908.jpeg photostudio_1541352921193.jpeg
    goldfinger and Mendel Leisk like this.
  9. Mendel Leisk
    42,348
    Yup, it's a bit funky, but it will REALLY save the hubs from rust. I also put a (single) drop of oil on each exposed stud tip, move it around with an old toothbrush. Then repeat maybe halfway through winter. You don't want to overdo, centrifugal forces could spin it out, make a mess.
    alanclarkeau likes this.
  10. Kiril
    Kiril Junior Member
    27
    34
    Sofia
    Excel
    Just put the winter attire on my Prius - Dunlop Winter Response 2 mounted on Tyota 15" 10 spoke hyper black alloy wheels.
    PS For Europeans - enter the setting menu, Vechicle settings, Maintenance, TPMS - press the center (Enter) button 3 times :) Be happy using TPMS set 2
    #10 Kiril, Nov 4, 2018
  11. Mendel Leisk
    42,348
    @Kiril is putting us to shame, anyway, put the snows on today:
    (Still up in the air.)
    Jeppefinn, Kiril and alanclarkeau like this.
  12. padroo
    2,763
    2,253
    Strictly function Mendel.
  13. Mendel Leisk
    42,348
    I'm getting cagey, trying to protect my back when swapping tires: my latest trick is to crabwalk the tire wheel/tire up, as close and oriented as possible, then lever it up and onto the studs with the help of a prybar tucked under. It invariably takes some jimmying, but if I try to just muscle them on I regret it, usually for weeks.
    When the wheels are off I dress the hub by running an old toothbrush around, spreading the remnants of anti-seize uniformly.
    Rona 2" abs end cap pushed onto the hub opening (with a rubber band gasket to fill the gap), a drop of oil on each open ended nut, chased around with aforementioned tooth brush, and it's good to go.
    #13 Mendel Leisk, Nov 6, 2018
    Jeppefinn likes this.
  14. padroo
    2,763
    2,253
    I have a technique for installing wheels. I have a stool I sit on and I move the wheel into position and try to rotate it so I don't have to try to turn it to align with the studs. I lay my forearms across my knees and both hands slightly below knee level and then just pivot my arms on my knees. I am able to install my 20 inch Prowler wheels this way and they are a foot wide. I need to make a video of it.
  15. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    243B571E-6D11-4672-BFF5-E20319791BFD.jpeg I just put my winter tire on as well.
    Kiril and Jeppefinn like this.
  16. Mendel Leisk
    42,348
    It doesn't count if you can't tell. :p
    Yeah I know, I know, those aren't stock fourth gen wheel covers, lol. But didn't you know: snow tires don't work, if they're not ugly as sin.
    Salamander_King and alanclarkeau like this.
  17. padroo
    2,763
    2,253
    We had snow on the ground this morning, put my winter wheels on just in time.
  18. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
    Snow this week including today. So, glad I put them on early. End caps are holding. photostudio_1542318866005.jpeg
    Jeppefinn, Mendel Leisk and krmcg like this.
  19. Salamander_King
    Salamander_King Senior Member
    11,024
    8,979
    New England
    We are expecting the first real accumulating snow tomorrow. Just in time, finished putting on brand new MB alloy wheels (cheaper than steely by courtesy of Discount Tire) and Xice snows for the first time. Even after consulting the manual and seeing diagram, I still could not figure out where the front and rear floor jack points are on PRIME (which should be similar to Gen4?). I ended up using the rocker panel jack points for each wheel. Using aftermarket external TPMS only on winter wheels, TPMS light did not come on initially. It took almost 1 hour, ~40 miles of driving for the car to realize that there are no TPMS. No audible warning. I think the warning light is far to the right of my view, it is easy to ignore.
    #19 Salamander_King, Nov 15, 2018
  20. Mendel Leisk
    42,348
    Good to hear that's working for you. I might be able to dig up a picture of what our hubs looked like after a few years exposed. Toyota's rust-proofing is zero, they were rusty as heck. I wire brushed them and put on some oil, then started using those caps.
