Winter tires - what are you running?
Discussion in 'Prius c Main Forum' started by goldnrod24, Nov 11, 2017.
  1. goldnrod24
    goldnrod24 Junior Member
    27
    Michigan
    2016 Prius c
    It's been a while since this was discussed.
    Yesterday, I had a set of Firestone Winterforce 2 tires mounted to my steel wheels. The OE Bridgestones are going on custom wheels for the good weather.
    I'm a big fan in the Winterforces. These are the 3rd set in my fleet. All mounted on steelies to save on the changeover hassles.
  2. jimnjo
    jimnjo Member
    117
    2015 Prius c
    Only our second winter with a "C" but sticking with OE tires that seem to do well enough in northern Michigan winter (mostly city) weather. Previously our "regular" 2006 Prius, in what I would call formidable driveway conditions also had enough traction without resorting to winter tires, though the traction control (happy to be able to easily turn that off now) caused some issues at times. Our experience is colored, I expect, by the little wimpy lightweight econoboxes we had before we started driving a Prius...
  3. goldnrod24
    27
    Michigan
    2016 Prius c
    Not many "cities" in N. Michigan. I'm in Frankfort, directly west of TC. You?
  4. jimnjo
    jimnjo Member
    117
    2015 Prius c
  5. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I have Michelin X-Ice XI3's mounted on my front wheels. I chose them because they were Consumer Report's top-rated tire, and I've been very happy with them. Last winter I was going up and down some icy roads with grades of something like 6% or so and I didn't have any problems at all. I'm not saying you can whip around corners on ice (maybe you can, but I haven't tried it) - but with cautious application of power I had no problems with traction in pretty challenging conditions.
  6. Mendel Leisk
    42,352
    Isn't having snows on fronts-only a no-no now? I did that with our first car, '81 I think, and noticed the back end trying to come around on a snowy downhill. Next car, in '82, the tire shop recommended all four should be snows, and we went with that.
    #6 Mendel Leisk, Nov 17, 2017
    Merkey likes this.
  7. skayaks
    skayaks Active Member
    123
    107
    Massachusetts
    +1 for the Michelin X-Ice XI3 but
    +4 for using them on all 4 wheels.
  8. Mendel Leisk
    42,352
    Yeah we've had X-Ice2 since purchase with our low mileage 2010, the're still around 8~9 32'ths inch all around; I get them off promptly in spring. They are great on bare roads, very quiet/smooth for a snow tire. Our winters are mostly bare roads with rain, periodic ice, snow just once in a while.
    scona likes this.
  9. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    I have the more base 15 inch wheels, its a prius C two. I am on my second set of tires. The first set was the factory low rolling all season. My current ones are cheap all weather tires. I live near Chicago, 2 winters ago lots of snow. The last winter for me snow only a few times, not justify winter tires.
    I might be moving from near Chicago, Illinois to Anchorage, Alaska (waiting to hear about a job). Should I change tires? the tires I got now have about 15K miles on them.
  10. tgpii
    tgpii Member
    382
    63
    Do winter/other tires other then low rolling, affect your MPG?
  11. Mendel Leisk
    42,352
    Any snow tire will be not so good for rolling resistance. The X-Ice have minimum impact though, Michelin gives it the GreenX logo. They're not in same league as an all-season LRR tire, but not bad.
    Merkey likes this.
  12. tgpii
    tgpii Member
    382
    63
  13. tgpii
    tgpii Member
    382
    63
    St. Ignace is a big city. Do you cross the Mackinac Bridge in winter?
  14. Sean Nelson
    421
    182
    Yeah, I've had this discussion in another forum. Given the number of drivers who don't even bother putting any snow tires on at all, it still seems a bit incongruous to me that I get criticized for putting on two of them.
    First of all, the BC Motor Vehicle act requires you to have snow tires on at least the primary drive axle on roads where snow tires are designated as mandatory. So legally speaking, snow tires on just the front wheels are fine (which is my primary concern). Secondly, since I don't commute by car I have the option of not driving on those relatively rare occasions in Vancouver where conditions are very bad. And thirdly, in well over 4 decades of driving front wheel drive cars with snows on only the front wheels, I've never had a loss of control, despite watching people ahead and behind me spinning out of control on a couple of occasions.
    That having been said, I have great respect for slippery conditions and I am extremely cautious in them. For people who don't have the temperament to drive slow enough or leave enough space ahead of you to avoid potential accidents, two snow tires might not be enough. Actually, my personal opinion is that such people probably shouldn't be out in those kinds of conditions in the first place.
  15. Mendel Leisk
    42,352
    I read through that a bit, and it seems like even their definition of "winter tire" is nebulous, encompasses both tires with mountain/snowflake AND tires that merely say M+S. The latter designation is on pretty much every all-season these days, so that seems a near completely toothless tiger. (n)
    I was just quickly googling, not sure if I found the definitive definitions:
    https://www2.gov.bc.ca/assets/gov/driving-and-transportation/driving/winter/pdfs/wintertiresinbc_handout.pdf
  16. Sean Nelson
    421
    182
    Yeah, M+S are counted as "winter" tires for the purposes of enforcing roads that require them. My main point is that the legislators chose to make them optional on the non-drive wheels.
  17. MichaelJai
    MichaelJai Junior Member
    toronto
    2017 Prius c
    Currently running on Hercules avalanche R G2 winter tires on steel rims. Got it for cheap on Kijiji from a guy who totaled his yaris. So far so good
  18. JMJCATH
    JMJCATH Member
    91
    52
    Here
    #18 JMJCATH, Dec 2, 2017
  19. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    4x Michelin Xi3s in 175/70R14 on a dedicated set of 14" steel wheels. No hubcaps. I can run over potholes with impunity.
  20. rjdriver
    rjdriver Active Member
    411
    172
    Rhode Island
    Was using Michelin X Ice Xi3, and they were a fantastic performer in snow. Much better than the appearance of their tread would imply. Had an 80 mile round trip commute at the time and even changing tires by season, the X Ice didn't last very long. So I got a set of General RT 43 all season and they are pretty good in snow, but the trade off is that they are only fair in rainy wet conditions.
    Change of job and commute is now only 8 miles, so reconsidering the X Ice again for next set.
