Winter tires?
Discussion in 'Gen 5 Prius Main Forum' started by Downrange, May 23, 2023.
  1. VelvetFoot
    VelvetFoot Senior Member
    1,408
    546
    New York State
    2026 Prius
    I might look into center caps then for under the hubcaps, since I'm in a salted area.
  2. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    The terms here might be confusing.
    The thing that covers the hub of a wheel is what we old people call a hub cap. The plastic dish that covers the entire wheel is a wheel cover.
    The incomprehensively expensive little insert designed for aluminum wheels is often called a center cap, but functions as a cap for the hub.
    At least, this is how I see the terms used most often.
    I see the wisdom in spraying something protective onto the hub no matter what cap or cover is used, but I wouldn't want any of that to migrate to a surface of the wheel that would interact with the wheel bolts. If you aren't supposed to get anti-seize on those surfaces, oil or silicone or anything else that might lubricate seems like a potential problem.
    #342 Winston Smith, Oct 14, 2025
    Merkey and Mendel Leisk like this.
  3. Mendel Leisk
    42,364
    That'd only work for the front, leaves the rears another conundrum.
  4. Mendel Leisk
    42,364
    Agree, I mean, it's the cap over the hub, the hub cap, lol. Still, the term has evolved, has generally come to mean the full cover. Can't fight the tide of opinion I guess.
    English is funny, take how we say the letter "W", "double-yew" I suppose. Or describing the word "continuum", which has a "double U". To someone learning English, what a conundrum, just a subtle change to the inflection.
  5. Gorgonzola
    Gorgonzola Member
    42
    28
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    After having my LE AWD for a full year and toughing it out for the first winter with the stock Toyo Extensa’s, I just installed a set of 205/65R16 Blizzak WS90’s on dedicated steelies. At first I tried to go for X-Ice Snow’s, but apparently they just aren’t available right now in my area. Blizzaks seemed to be the next best alternative. After driving about 60 miles at highway speeds, I was pleasantly surprised to learn that the Blizzaks are not nearly as loud on dry pavement as I had expected (based on mentions of road noise on this thread and other places across the interwebs). They’re only marginally louder than the stock all-season Toyo’s; very easy to live with thus far! We’ll see what this winter brings
  6. VelvetFoot
    1,408
    546
    New York State
    2026 Prius
    I had the X-Ices on a TDI Beetle, where I was following the mpg's.
    No loss of mpg's. Quiet. Long lasting.
    Not too great in the snow though, as I recall.
