Winter warm up routine?
Discussion in 'Gen 4 Prius Main Forum' started by The Professor, Oct 8, 2018.
  1. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Winter is coming...
    Coming from my previous standard ICE car, I would get my car warm inside, and free of snow/ice on the outside by starting the engine, pressing the windscreen defrost button, putting on the heated windows, heated seats, heated steering wheel (already miss that!), then going outside to clear the vehicle of snow (brush), and ice (de-icer spray). By the time I'd finished, the inside of the vehicle was always nice and warm, and my younglings didn't complain when I put them in.
    But in a Prius... there's no guarantee the ICE will even turn on, or is there?
    What are your winter warm up tips and tricks to get that ICE heated up?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    Press accelerator and the ICE will start. Or put the heater on.
  3. The Professor
    598
    809
    UK
    Excel
    By heater you mean just putting the temperature up on the climate control?
    alanclarkeau likes this.
  4. alanclarkeau
    7,045
    7,589
    Yep - and press
    with the temperature set higher than ambient, should kick the ICE on to provide heat.
  5. The Professor
    598
    809
    UK
    Excel
    Good to know - thanks!
  6. alanclarkeau
    7,045
    7,589
    If I DON'T want it to start the ICE (sneak out so my dogs don't hear me - though they will anyway - they went to the door when I left) - I hit "EV" and the "AUTO" OFF within 7 nano-seconds of POWER. EV isn't necessary - but means I've a bit more leeway with how much I can press the accelerator without it firing.
  7. Prodigyplace
    12,403
    11,681
    Central Virginia
    Turning on the defroster starts the engine. EV only works under certain conditions and is cancelled if above 20 mph.
  8. The Professor
    598
    809
    UK
    Excel
    It seems pretty simple then... as I'd be hitting the front windscreen defrost button anyway, it sounds like that starts the ICE.
  9. GadgetVirtuoso
    Fort Worth, TX
    2018 Prius
    You won't have any issue with the ICE coming on during the winter. Even in North TX during the winter the ICE usually stays on until the engine is warm and as others have said if you start turning on the heater and defrosters the ICE will come on.
    Starship16 likes this.
  10. Mendel Leisk
    40,574
    The one start-up scenario I hate is when the car's been parked outside for a few hours, windshield is frosted. You pretty much are forced to sit idling till things are warmed up enough to clear the glass.
    If this is happening in your own driveway, in front of a garage filled with stuff, there's something you can rectify: I've never had frost/fog with a garage stored car, though ours is an attached garage, and our winters are relatively mild.
    Something else that'll speed the warm-up: the block heater. Two hours is usually enough to plateau the coolant temperature, about 30C above ambient.
    Tideland Prius likes this.
  11. Tideland Prius
    16,445
    An EBH definitely helps speed things along. Windscreen defrost will turn the engine on but i would turn off the defrost (go back to AUTO) once the engine is on. My reasoning? In AUTO, the fan stays off initially, allowing the engine to warm you. In defrost, the fan is running at full speed, taking whatever little heat there is from the engine, so the engine takes longer to heat up.
  12. JosephG
    JosephG Active Member
    115
    102
    2018 Prius
    The hybrid system starts up to lubricate the engine if it is cold outside anyway. Unless you live in a very cold climate, a block heater is probably unnecessary since the Prius actually stores hot coolant in a vacuum insulated container to warm-up the engine faster. Whenever your engine shuts off (at power down or EV mode or whatever), some hot coolant is kept in this container to get the engine warm fast when it needs to turn on again.
    #12 JosephG, Oct 9, 2018
  13. alanclarkeau
    7,045
    7,589
    I don't think that feature made it to Gen 4 - I think I read that it was dropped at Gen 3 mid-term update. Replaced by an Exhaust Heat Recirculation System - and that only on some markets, think it said part USA and Canada. I don't think it's on ours here.
    - start at 17:55 (unless you've got 37 mins spare - it's actually quite interesting eg, the Muffler valve to allow less restricted flow under some situations, but which is normally running in quiet mode).
    Starship16 and Mendel Leisk like this.
  14. Prodigyplace
    12,403
    11,681
    Central Virginia
    The 2nd Gen US Prius was the only one that used a vacuum insulated container to store warm coolant. The 3rd Gen and your 4th Gen do not have that.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    That is my biggest gripe with the Prius. My Gen 3 used to take about 10-15 minutes to clear frost and then I was left with only the bottom half of the screen cleared of mist, then it took a further 5-10 minutes to clear the top half of the screen. The Gen 4 is a bit quicker maybe 5-10 minutes, and does clear the whole screen of mist.
    The last car I had before going hybrid in 2010 was a 2008 Ford Mondeo which had a heated (element) front screen, this cleared the screen of any frost or mist in less than a minute. The patent Ford had on these ran out around 2011 IIRC, so I don't know why Toyota didn't adopt them for the 2012 on models, it saves a lot of fuel and pollution on winter start ups. Maybe it was a weight thing ?
  16. Mendel Leisk
    40,574
    I wish there was a regular ventilation mode that was windshield only, not windshield/heat-to-feet. This:
    versus:
    Most cars do offer both. I appreciate there's the special front windshield defog option, that invokes AC as well, but I'd just like that extra vent mode.
    dubit likes this.
  17. Prodigyplace
    12,403
    11,681
    Central Virginia
    Gen 4 has it ;)
  18. Mendel Leisk
    40,574
    I'm not seeing it:
  19. Tideland Prius
    16,445
    IT might be a moot point since technology hasn’t improved but myself understanding is that the heating elements can sometimes cause interference with the onboard GPS receiver. Also I guess there’s that weird glint if the sun angle is just right and reflects off the wires.
  20. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    That's correct. Those are the vent settings.
    Or you can press the front windshield & mirrors defrost button. But there's no fan action with that button.
