Wiper blade sizes
Discussion in 'Gen 3 Prius Main Forum' started by lenjack, Oct 9, 2009.
  1. jeff618
    jeff618 Junior Member
    28
    Waterford, WI - USA
    Especially if you're in the ice & snow country...bye bye wiper motor!!
  2. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    After 2 years I had to replace my front blades... Local Toyota dealer wanted $100 for the two front "full assemblies". Decided to get the genuine Toyota replacement rubber only for $15 total.
    Have some step-by-step instructions and pics that may help those who are a bit timid about attempting it...
    How To: Change Front Windshield Wiper Blades on a 2010 Toyota Prius
  3. jeff618
    28
    Waterford, WI - USA
    I wish I had the time, skill and patience to do this but I simply don't. Plus, with abusive Wisconsin winters, replacing the whole wiper assembly is some inexpensive insurance. I love the NeoForms I mentioned above and the installation is literally 2 minutes max. Here's the whole procedure.
  4. stannc
    stannc Junior Member
    24
    North Carolina
    Unfortunately, the blog that the above link referred to has been removed.
    Has anyone archived or reproduced those steps?
    Thanks.
  5. jeff618
    28
    Waterford, WI - USA
  6. FractionalDerivative
    Replacing wiper blades seem ridiculously easy. But knowing me I'll probably break the whole assembly. My front driver side wiper leaves streaks. But it hasn't been an issue for a few months since were in the middle of a drought. Will a Toyota dealership charge you to replace the blades, or just charge you for the blades themselves?
    AlexAndu87 likes this.
  7. fatfingers
    fatfingers Junior Member
    If you are looking for a better blade then it's a personal preference. If you're trying to save money your dealer should have wiper inserts and it should be the cheapest way to go. They are not hard to install and most dealers will install them for free.
  8. yeldogt
    yeldogt Active Member
    810
    313
    NE
    On our Lexus vehicles we always use the replacements from the dealer -- they are inexpensive to purchase and made from high quality rubber......... only takes a few to switch out the rubber and replace. We do the same with the Nissan and many of the European brands that sell the inserts. The frames are well made with friction points that hold up -- we have some that are 10 years old and still going strong. Don't throw out the original wipers.
  9. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Does anybody know if wiper blades are warranted under the 36K bumper to bumper warranty ?
    REV
  10. fatfingers
    No The inserts are considered a regular maintence item.
  11. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    trico refills
    parts.com
    when i ordered them, the numbers for 2010 were incorrect
    use 2011 for 2010
    shipping is a little expensive for such a light item
  12. kenoarto
    kenoarto Senior Member
    395
    Chicago, IL
    I've been using 28" blades on my driver's side for a very long time. Bottom chatters a bit, but I much prefer the larger area being wiped. Also be sure to measure the passenger side wiper blade at the actual rubber. Most are a half an inch to an full inch short allowing for an inch larger.
