Wiper blades
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jonny Zero, Oct 18, 2012.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    What do you guys use for replacement wiper blades, front and back.
    I am not a fan of using the rubber inserts from Toyota and usually replace the whole blades when I need too, but I notice the Prius blades are more curved and probably have some aerodynamic effects. Which aftermarket replacement works well?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I tried an aftermarket and you are correct about the curvature. The ends would not touch the windshield.
    I have since bought the Toyota rubber inserts and transferred the metal inserts that create the curvature. I have averaged about 18 months between changes. I get all three inserts for about $20.
    I am just not a fan of replacing the whole blade assembly when only the rubber insert is worn.
  3. gliderman
    gliderman Active Member
    751
    225
    I am a big fan of Michelin Stealth Hybrid Technology Beam Blade. They hug the window tight, and last a little over a year for me.
  4. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    I've used Anco Contour blades, and they have so far lasted about a year...
  5. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    I use RainX and don't even need the wipers. Except for morning dew.
    Blu-ray likes this.
  6. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    I'm on my second set of the Michelin Stealth Hybrids. They are curved like beam blades and have the aerodynamic covers. So far, so good.
  7. eaglesight333
    eaglesight333 Senior Member
    7,220
    84
    Northern, IL
    I went with Valeo 600-26 Series Wiper Blade, 26", Valeo 600-19 Series Wiper Blade, 19" and Trico 16-A Exact Fit Rear Wiper Blade, 16" through amazon via consumer reports. I installed them two weeks ago and they are working great so far.
  8. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Went to Kragen auto (now O'Reilly) to look for some wipers for my parents' vans. I saw the Trico Exact Fit Hybrid blades that look just like the OEM Prius blade. I have no comment on the performance though. My original blades are still good but will need to be replaced by next year.
    TRICO Exact Fit®: Original Factory Quality | TRICO® scroll down to the hybrid blade to see the picture.
    TsKarma and Jonny Zero like this.
  9. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Whatever you do, do not throw away the original blade assemblies. They cost $40+ each.
    iPhone ?
  10. 72fordgts
    72fordgts Member
    132
    35
    ON, Canada
    We've had Bosch Icons on for the last year and they are still great.
  11. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    Goodyear Assurance from Costco. They had a buy 1 get 1 free last month but didnt want to buy them just to have them sit at home, $7.99 each though. Our Infiniti has them and they conform to any shape and look identical to the blades that came on our Camry. They are frameless as well.
    http://www.goodyearwiperblade.com/?mid=main
  12. The Critic
    3,193
    2,333
    CA
    Just installed a set of those yesterday on a co-worker's car. Adapters and frame are super flimsy. Not a good quality blade.
    iPhone ?
    TsKarma likes this.
  13. janice45
    janice45 Dudley Girl
    82
    maine
    I bought the Bosh blades they fit the best .I tried other blade replacements of other brands and they stood away from the windshield to much (kinda in my site line)
    The bosh are low profile and work really well
  14. Den49
    Den49 Member
    498
    272
    Maryland
    I've had the Bosch Icon beam blades for about the last eighteen months on the Prius and they have worked flawlessly. I have also used Bosch Marathon beam blades on another car and found them to be not as good as the Icon, lasting only about nine months. If you go with Bosch, get the Icon rather than Marathon. They look the same, except for the top profile of the beam, which may have something to do with why the Icon performs better than the Marathon. However, the Icon is more expensive, about $45.00 per pair, vs. about $30.00 per pair for the Marathon, before any discounts or sale prices. I don't know whether the Icon is being phased out. In my shopping area, it seems that the Icon is sold in the auto (Advance Auto) stores and no longer sold in the discount (Walmart) stores; whereas the Marathon is now sold in the discount stores in place of the Icon.
    I have not replaced the rear window wiper blade because it never gets used.
  15. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I replaced my original blades with RainX wipers and they work almost as well as the originals. They look a little clunky in design but I was in a hurry and didn't have time to get to the dealer. I did keep the original blades so I can have the inserts replaced in the future.
  16. Adam Leibovitch
    498
    102
    I have the inserts from a set of bosch blades that they sell at toyota.
  17. clifford
    clifford Member
    156
    I have been very pleased with the toyota oem. Don't really see a reason to change.
  18. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    I like the Rain X blades. Once the dealers crappy windshield washer fluid is gone I'm going to replace the blades and start using the Rain X windshield washer fluid. I live in Central West Florida and it is pretty much a necessity with our afternoon thunder boomers and torrential downpours.
  19. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Replace all 3 yesterday for the 2nd time in 75K miles. Used Toyota inserts both times.
  20. terrileew
    terrileew Junior Member
    Denver
    Interesting. Tried to buy inserts at my dealership a few months ago and was told they don't make them and you now have to buy the entire blade. Not happy.
