Wiper replacements
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Bob-blehead, Feb 20, 2015.
  1. Bob-blehead
    Bob-blehead Junior Member
    52
    Central Michigan
    2014 Prius v wagon
    Yesterday, I was in a local store (Meijers) looking at some front wiper replacements. I was looking at Bosch Icons because I have used them on our other vehicles, and I really like them. When I looked at the guide books in the store, it showed that the Icons worked on the '12 and '13 Prius v, but apparently not the '14. The Bosch website says that the Icons are not compatible with the '14 either. I wound up picking up a pair of Trico blades.
    Anybody have any idea why they would be listed as compatible on the 2 earlier models, but not the '14 v?
  2. rdgrimes
    rdgrimes Senior Member
    1,660
    393
    New Mexico, USA
    My assumption would be that the connection to the wiper arm has changed. You could confirm that by looking at a '14.
  3. Bob-blehead
    52
    Central Michigan
    2014 Prius v wagon
    I would have to compare my '14 to a '12 or '13. Was just looking to see if anyone knew for sure off hand.
  4. kithmo
    kithmo Couch Potato
    2,384
    2,721
    47
    South Yorkshire, UK
    What size wipers does the v have ?
    The UK equivalent, Prius plus, has very odd sizes, 700 mm (27.5") and 350 mm (13.8") on the front. Most non OEM wiper blades listed for the Plus are 26" and 16" same as the Gen 3 Hatch and cost around £10 GBP a pair. I had to go to the dealers where they had to order the rubber blade inserts which cost me £24 GBP. I was wondering if it would hurt to fit the 26" and 16" set next time.
  5. Bob-blehead
    52
    Central Michigan
    2014 Prius v wagon
    They list 26" and, I believe, 19" for the front.
  6. Mr_Raja
    Mr_Raja Junior Member
    16
    Germantown
    Did you check Rain-X? I have been using Rain-X Latitude for about 3 years now. I used to prefer Bosch but, to me, Rain-X performs better.
  7. Bob-blehead
    52
    Central Michigan
    2014 Prius v wagon
    I am not a fan of the Rain-X Latitudes. I have a pair of those on the Rav4, and I will be changing these too in the near future. I'm glad that you like them, but my experience has not been as positive.
  8. J L
    J L Junior Member
    30
    Northern VA
    2013 Prius v wagon
    I'd also go with the assumption that the wiper arm hook is a proprietary design or something. I found it much easier to just order the rubber inserts and change those instead of the whole blade.
Loading...
