Wiper woes
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tgpii, Feb 18, 2014.
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    When to turn on my wipers on. I notice some rubber hanging off the passenger side wiper on my Prius C. So I will replace the wiper. I hate how the passenger side wiper is so much smaller. A bigger wiper can push more snow and ice. Anyways should I go with stock or get some after market wiper? Why or why not? Would that be covered by the warranty/secluded maintenance? Also sometimes when I shift it into gear the lights on the shifter don't always light up. What would cause this? That should be covered by the warranty Thanks.
  2. JC91006
    16,481
    8,397
    I would let Toyota handle it through warranty and free maintenance
  3. orenji
    orenji Senior Member
    5,884
    3,486
    The loose rubber should be covered by Toyota, can't do anything on a short wiper, you will just have to get used to it.
  4. JC91006
    16,481
    8,397
    The wiper size is engineered to give the best visibility to the driver and the size of the wiper blades are the largest available for the windshield size. I don't think you can put a larger one on and still have it functional
  5. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    The blade is shot. It's a replaceable maintenance item and will not be covered under warranty.
    Replacement blades are cheap and plentiful. I get mine at wal-mart, though they are sold in any good parts store, as well. Get one the same size, as they will be in the selection mix. They are easy to replace and you should replace your wipers at least once a year. I change mine about twice per year or whenever they start streaking.
    The tough one is the rear wiper. I won't go to the stealership unless I have to, so I just got a long wiper refill and cut a portion out to replace on the arm. But I had to remove the 10mm nut holding the wiper on and take the wiper into the garage to figure it out and make the change. The tougher part is going to be finding a wiper that will fit that is a couple of inches longer.
    tgpii likes this.
  6. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Try not to use your wipers to remove ice/snow. The wiper arm connection is probably made of plastic and is design to shear if too much force is placed on it. I should know, it happened to me on my '82 subaru. :eek:
  7. orenji
    5,884
    3,486
    All parts of the car except tires are covered by Toyota for 12 months, 12,000 miles, wiper blades will be covered. Tires have there own warranty from the maker.
  8. tgpii
    tgpii Member
    382
    63
    Only cost 5 bucks for a new one.
  9. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    The passenger wiper is small because the driver's wiper is huge. Together they clear the most % of the windshield versus making them equal size. Likely the rubber sheared off because of the winter weather - possibly try to use them when they were frozen to the windshield? Happens all the time. I've tried several non-Toyota brand replacements but can't seem to find one that works as well as Toyota OEM, and doesn't look dorky on the car at the same time.
  10. tgpii
    tgpii Member
    382
    63
    The Toyota OEM wiper for the passenger side was only 5 bucks. For that price. . .
  11. JPTuck
    JPTuck Member
    110
    29
    South Deerfield, Mass
    I like to change mine once a year even tho I use a dedicated snow blade during the winter. To buy a set of summer inserts for the wiper blades from Toyota that the Prius came with cost a little more than $11 with the rear the more difficult to replace.
  12. carolD
    carolD Junior Member
    82
    florida
    2015 Prius c
    I bring my car to Toyota for everything. You don't want to get the wrong advice. Regular mechanics do not know a lot about these cars. I trust Toyota.
  13. Faster345
    Faster345 New Member
    SoCal
    2015 Prius c
    Amazon has wiper replacements for all cars. Also I suggest applying Rain-X to all your car's exterior glass. Water just beads off, and at highway speeds you don't even need to run the wipers. Cheers.
  14. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Check the date, this thread is a 2014 thread.
    I'm kinda assuming the OP has his wiper problem resolved by now.
  15. Mendel Leisk
    38,709
    Ah woops.
    Maybe the real old threads should display with cobwebs, hehe.
  16. orenji
    5,884
    3,486
    With RainX you can delete your wipers all together! Less drag and looks better!
  17. Faster345
    SoCal
    2015 Prius c
  18. orenji
    5,884
    3,486
    or left! ;)
  19. Okinawa
    Okinawa Senior Member
    1,333
    317
    The wiper will not be covered by warranty. When you go to your Toyota dealer for something just go to the parts department and buy 3 inserts and ask the service department to put them on for you. They will usually do it for nothing.
  20. orenji
    5,884
    3,486
    I have noticed the plastic arms that hold the inserts are becoming dry with the hot sun we have. I may need to replace it all.
