Wire color for steering wheel horn button
Discussion in 'Gen 3 Prius Technical Discussion' started by MrTea, May 9, 2012.
  1. MrTea
    MrTea Junior Member
    29
    Topeka, KS
    Does anyone know which wire do I have to tap into to wire the horn button on the steering wheel and where the wire is located?
    I plan to use the horn switch for other purpose. :rockon:
  2. ajtozzi
    ajtozzi Junior Member
    94
    LT Blue
    (-) negative trigger
    Dash fuse box, white 40 pin plug, pin 24
  3. MrTea
    MrTea Junior Member
    29
    Topeka, KS
    Thanks. Do you have photos on how to get to that wire?
  4. Seymour1
    Seymour1 Member
    272
    36
    I need to find the horn button wire under the hood. There is a horn relay in the under-hood fuse block. The horn button should be connected to that relay with a wire. I looked briefly for a light blue wire but could not find it. I tried to find a circuit diagram without any luck.
    Today, I mounted my new fiamm horn (Farbin brand) and connected 12 volts and ground. It fits in front of the radiator. Now I need to connect the relay coil. I am connecting the new horn in an unusual manner.
    Thanks
  5. ChapmanF
    18,947
  6. Seymour1
    Seymour1 Member
    272
    36
    I bought a Haynes manual but the horn circuit is not shown. I searched the wiring diagram pages 2 times. Maybe my library will have better manuals.
  7. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    Here ya go...
