Wire disconnected
Discussion in 'Gen 3 Prius Technical Discussion' started by Violet martin, Jul 2, 2021.
  1. Violet martin
    Violet martin New Member
    Central square, ny
    I noticed a disconnected wire today. It looks purple. Anyone know what this wire is for and where it should be attached. It’s on the passenger side on the backside of the engine. I’ve attached photos.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,932
    6,859
    Texas Hill Country
    That second pic looks like a ground wire broken off on the right side.
    Valiant V likes this.
  3. ChapmanF
    18,918
    Looks to me like something that once connected to that suspiciously-wireless light gray connector right next to it.
    I might have to search a bit to see what that is. From the position, I was tempted to think crank sensor, but if it were that, you would have asked "why won't my car start?".
    Edit: there it is, connector D26, engine oil pressure switch. Takes a single wire, and it's violet.
    Disconnected, you will never get a warning if the engine oil pressure goes dangerously low.
    #3 ChapmanF, Jul 2, 2021
  4. Violet martin
    Central square, ny
    Thank you! I’m bringing it to Toyota on Monday.
  5. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    So they come that way from the factory then? [*rimshot*]
  6. ChapmanF
    18,918
    And deprive owners of the chance to ignore a warning light? Notta chance.
