Wiring DRLs
Discussion in 'Prius v Accessories and Modifications' started by Mianda, Jan 5, 2022.
  1. Mianda
    Mianda New Member
    Cedarburg, WI
    2013 Prius v wagon
    Installing this combination turn signal/DRL on my 2013 V. Has anyone installed these? If so, where did you pull the power for the DRLs?
    Thanks in advance for any advice!
    52,863
    very attractive!(y)
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I used a fuse tap and a relay to get power for my LED foglights used as DRLs directly from the fusebox.
    Used the 12v constant on/hot terminal for power. Tapped one of the 5amp fuses in the front right row of the fusebox to trigger the relay in Ready Mode, I think it's the inverter pump fuse, or something like that.
  4. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    I bought these for my 2012 v Five, then removed them, relying instead on an 'on when +12.8V' relay powering much brighter yellow LEDs with white halos replacing the fogs.
  5. xliderider
    8,140
    3,280
    Honolulu, HI
  6. Mianda
    Mianda New Member
    Cedarburg, WI
    2013 Prius v wagon
    Thanks xliderider.
  7. Centerpunch
    Centerpunch Active Member
    151
    141
    OH / NC
    2017 Prius v wagon
    Who sells an “on when 12.8v relay”? This is the closest thing I’ve found:
  8. Air_Boss
    4,259
    1,197
    New Yawk
    #8 Air_Boss, Jan 14, 2022
  9. Centerpunch
    151
    141
    OH / NC
    2017 Prius v wagon
    What looks like a random ad in my post is actually a link I posted to an Amazon item.
  10. Air_Boss
    4,259
    1,197
    New Yawk
    So random that nothing appeared!
  11. Centerpunch
    151
    141
    OH / NC
    2017 Prius v wagon
    trying again
  12. Centerpunch
    151
    141
    OH / NC
    2017 Prius v wagon
    or maybe
    amazon.com/dp/B07929Y5SZ
  13. xliderider
    8,140
    3,280
    Honolulu, HI
  14. Air_Boss
    4,259
    1,197
    New Yawk
    Same idea, but why not keep it simple?
  15. Slammed
    Slammed Junior Member
    So I do have these on my Prius but I'd like to turn them on with the headlights, is that possible?
  16. Air_Boss
    4,259
    1,197
    New Yawk
    DRLs with headlights as well as independently? If they are always on, they are on with headlights.
