Wiring harness for hv battery 2010 prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Cheryl806, Nov 8, 2023.
  1. Cheryl806
    Cheryl806 New Member
    Lubbock Tx
    Bought a reconditioned hv battery. It only has 2 clips. One of the large clips obviously goes to fan. Not sure about the second large clip. But the reconditioned battery does not have the 3rd and smaller clip. What does this clip go to? And what can I do. Core is gone.
  2. Cheryl806
    Lubbock Tx
    The wiring harness is apart of the hv battery fuse. Will that make it some sort of sensor?
    #2 Cheryl806, Nov 8, 2023
  3. Tombukt2
    Tombukt2 Senior Member
    13,757
    2,491
    Durham NC
    This is the harness that plugs in right there at the HV battery computer into that white and magenta and red box it stands up outside of the battery pack right there under the strut tower if you will something to do with some wireless something. If you're missing something there then a plug will be hanging I don't think it'll cause you any strife if you don't have the option anyway
