Wiring Harness Recall (J0T) - REMEDY UPDATE - Questions Remain
Discussion in 'Gen 4 Prius Main Forum' started by JackTheNarrator, Nov 19, 2018.
  1. Prodigyplace
    12,560
    11,778
    Central Virginia
    Apparently it needs to be the dealer that performed the recall. I did not trust my local dealer for the original recall so I drove 150 miles to my selling dealer. I had to do that again yesterday. Since my local dealer did not perform the original recall, they could not add the extra tape, according to Toyota Corporate.
    #41 Prodigyplace, Dec 7, 2018
    UltraJetRefill likes this.
  2. UltraJetRefill
    156
    93
    Tucson, AZ
    Just an update on our two Priuses. Both of them have abrasion marks on the passenger's side cable bundle, but I didn't see any wires through the original tape. I will probably call corporate next week and explain the situation, since my dealer said last month said they already did the fix and couldn't do any more. Maybe things have changed since them. I guess I should call the dealer first.
    Prius #1 with 9000 miles:
    Prius #2 with ~6000 miles.
    BTW, #1 with 9000 miles is probably going back to the dealer since they seem to have missed taping the driver's side far enough to protect from the contact point on the bottom:
    Prius #1 (driver's side):
  3. Prodigyplace
    12,560
    11,778
    Central Virginia
    The recall has been amended to inspect and tape both sides.
    I called corporate to see if my local dealer could tape the passenger side. They said I needed to go back to the dealer that did the recall Corporate called the dealer before I did. They had no problem with me bringing it back to do the passenger side.
  4. UltraJetRefill
    156
    93
    Tucson, AZ
    Cool! I'll give corporate a call on Monday.
    Prodigyplace likes this.
  5. Prodigyplace
    12,560
    11,778
    Central Virginia
    You may want to look at the attachments in the first post of this thread.
    When my service manager called me he said he had the new documentation. The date he told me match. He said there was no additional service. He subsequently checked with his master technician who did my recall. He called me back and apologized after he had been corrected. No problem after that.
  6. JackTheNarrator
    50
    Los Angeles
    Prodigy posted:
    Question:
    What about those owners that had the original remedy done (tape only one side) and do not call corporate? Is Toyota re-notifying/mailing to them explaining that the original remedy they had done is not adequate?
    Question 2:
    The wires inside the tubes control certain vehicle systems. What happens to those systems when the wire pertaining to it is damaged?
  7. UltraJetRefill
    156
    93
    Tucson, AZ
    Funny, but I called the 'Contact Us' phone number on the Toyota Owners web page a few weeks ago, and they were not very helpful. They checked the VIN and said the recall fix had been completed. I said that the left side was taped but the right sight wasn't done. They said that there's nothing to update. I called the dealer back, and they said yes, we'll tape the right side. I'm not quite sure about the disconnect, since the update to the original recall was dated something like 15 Nov 2018.
    For #2: if the wires are damaged, I think they have to replace the wiring harness if the plastic sheath on any of the individual wires is damaged and copper is exposed. That is a major bit of work (check this document):
    https://static.nhtsa.gov/odi/rcl/2018/RCRIT-18V579-5292.pdf
    #47 UltraJetRefill, Feb 2, 2019
    JackTheNarrator likes this.
  8. JackTheNarrator
    50
    Los Angeles
    Thanks, Ultra.
    #2 Q a bit different
    While driving -
    if damage affects one of the wires within the harness of the untaped side - what happens to that wire's system?
  9. Elektroingenieur
    2,515
    3,284
    Three Touring
    Do you have some evidence that the original remedy is not, in fact, adequate to address the defect?
    Is such damage likely? Has anyone found exposed conductors or primary insulation (not just deformation of the outer wrapping from intended contact with the rigid plastic protector) on the harness for connector C32?
    Remember, too, that unlike the harness for connector C33, which has +B and IGCT power supply wires, the harness for C32 just has the twelve signal wires for the excitation and detection coils of the motor and generator resolvers, plus a shield. I’d be surprised to find enough energy in the C32 harness to ignite anything.
    As for what would happen if wires were broken or shorted, in the descriptions of the Motor Resolver Circuit and Generator Resolver Circuit in the Repair Manual (more info), Toyota writes, “If the resolver is malfunctioning, the vehicle may not drive smoothly.” See also the information for DTCs P0A3F16, P0A3F1F, P0A3F21, P0A3F22, P0A4B16, P0A4B1F, P0A4B21, and P0A4B22 and their entries in the Vehicle Behavior Chart.
    Prodigyplace and alanclarkeau like this.
  10. Tande
    Tande Active Member
    539
    322
    Mich.
    FWIW.......my neighbor has a 2016 (Gen 4) that had the entire harness replaced for this reason......
  11. UltraJetRefill
    156
    93
    Tucson, AZ
    Man, after looking at the pdf outlining the repair for the wiring harness, I shuddered at the thought of someone undoing all of those factory-torqued fasteners. It's probably just my tinfoil hat being on too tight, but I would really worry about 'new' problems after having that much work done. I get right side taped soon. Keeping fingers crossed...
    The actual repair starts on p.21:
    Tande likes this.
  12. Elektroingenieur
    2,515
    3,284
    Three Touring
    Do you know if the damage was on the harness for connector C32 (“RH (Passenger Side)” in the recall instructions), connector C33 (“LH (Driver Side)”), or both?
    alanclarkeau likes this.
  13. Tande
    Tande Active Member
    539
    322
    Mich.
    No, I do not......wish I did........what I do know is, she (elderly widow lady) had taken the car to the Toyota dealer for scheduled maintenance when it was discovered (no symptoms).......she was told about the bare wires (she, of course, has NO idea what they are talking about) & it would be covered under the recall .......as I remember, it took about 3/4 days to get the harness & R&R.......they did give her a loaner (y)
  14. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    Can someone tell me how to inspect the part of these two cables that are not visible from just looking at it directly.
    I'm assuming that cowl plastic black cover needs removing first?
    SM-N960U1 ?
  15. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Wow, I'm sure glad I got mine done sooner than later. Seems like a heck of a job to replace it and would have hated toyota to basically take apart and reinstall the motor.. I figured it was a stupid problem that most likely never was an issue but it seems like several others had issues with the wires getting worn!
  16. fsu23phd
    fsu23phd Active Member
    186
    114
    Wilmington, NC
    Hey Folks. Have any of you had this done already? How long did it take? I'm scheduled for monday and I need to decide if I am staying there or getting a shuttle to the office. Thanks
  17. UltraJetRefill
    156
    93
    Tucson, AZ
    I think mine was 1.5 h. I just chilled in the dealership and tried to drink all of their coffee.
    fsu23phd and Prodigyplace like this.
  18. fsu23phd
    186
    114
    Wilmington, NC
    Awesome, thanks for the info. They told me it would be about an hour and 20 minutes, but I didn't believe it. Good, I can hang out for that long. All the best
  19. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
  20. Prodigyplace
    12,560
    11,778
    Central Virginia
    Just like any other recall. Register with Toyota owners site & they will list it. Do you have a Gen 4 Prius in addition to your Prime? The engine wiring harnesses are likely routed differently.
