With a steady gas pedal battery keeps switching to electric motor.
Discussion in 'Gen 2 Prius Technical Discussion' started by Solarman44, Oct 5, 2009.
  1. Solarman44
    Solarman44 Junior Member
    78
    Largo, FL
    When I’m cruising on the highway at a steady speed my 2004 just started switching back and forth to the EV mode. With the MFD in the consumption screen I just noticed yesterday that the yellow arrow from the battery would come on for a second and then off for about 10 seconds and then back on again, over and over as long as I kept my pedal steady. This happens with blue bars and all the time now.
    I took the car into the dealer today and they “said†they could not find a problem. They claimed to have taken it on the road but didn’t see anything. I told them to keep looking as this is not normal. In the 5.5 years of driving the car this has never happened, has anyone else had this problem??? I really need some advice on this one.
    Thanks,
    John
  2. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    What's puzzling to me is that you haven't noticed it before. This is normal behavior for the conditions you describe.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    Yup, absolutely normal and absolutely not a problem. It's how the car works...it continuously "borrows" energy from the battery and then stores some back in there as the road subtlely fluctuates. That allows it to maintain a constant, efficient, ICE RPM rather than reving and lugging to compensate for energy need or surplus.
  4. Solarman44
    78
    Largo, FL
    Thanks everyone for your input. It just worried me that the arrow was doing this constantly at a steady speed and I don't recall ever seeing it do this that much, kind of like a kid playing with a light switch, on and off, on and off.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    The system in steady-state highway always shuttles a little
    current in and out of the battery, but it's only a couple of
    amps -- just a trickle as long as you're sitting around 60% SOC.
    The arrows don't show you how *much* is going on there, one of
    the long-standing failures of that display...
    _H*
  6. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Hi Solarman. Think of the MG+Battery in this case as acting a bit like a "load leveller". In a normal car the engine has no choice other than to exactly match the power demanded by the current speed, terrrain and accelerator pedal setting - even if it results in it running at an inefficient operating point. In the Prius on the other hand, as the power demand changes slightly the ICE can maintain a more efficient operating point and shunt power either to or from the battery to make up the difference.
  7. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    Very normal
