With my low mileage, OK to skip this year's SYNTHETIC OIL change?
Discussion in 'Prius c Technical Discussion' started by davide, Aug 22, 2018.
  1. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Check your oil level. Driving in ECO mode and slower than most drivers doesn't protect you from a possible leak. Besides, checking your oil regardless is easy and important. Too many posts of people who didn't check and "expected" their oil level to be fine, only to discover it wasn't. IMO you just need to check your oil not count on the unknown and unseen expectation that your oil level is fine. Confirm.
    We all make decisions and do things as our personal budget allows. But IMO budget or otherwise for most people their vehicle is one of the bigger purchases they make and own.
    After making that investment? I never understand the approach of then going frugal on Oil Changes. Comparative to most other maintenance, oil changes are one of the least expensive things we are burdened with doing, in maintaining a vehicle.
    Even with the supposed durability of synthetic oil and the relatively low miles accumulated since your last change, I would still maintain the schedule and change it. Most recommendations from manufacturers are to change yearly, regardless of mileage.
    Unless you are trading life sustaining medical treatment for the cost of an oil change, my advice is very "Nike"....just do it.
    You will then have another whole year of NOT having to worry about it. And if you are diligent about checking the oil level, one less risk to the vehicle and one less worry. IMO...well worth the cost of an Oil Change, especially on the average of 1 every 365 days.
    Starship16 and Mendel Leisk like this.
  2. papafern
    papafern Junior Member
    62
    NYC
    2015 Prius c
    I knew I read every 10k somewhere but the mechanics said no way!!! I have been changing it every 7 or 8k. Thanks
    Starship16 likes this.
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Canada recommends every 10k km.
  4. papafern
    62
    NYC
    2015 Prius c
    Oh, so it's every 10k KM??? Not miles???
  5. Mendel Leisk
    41,428
    In Canada, t's every 6 months or 8000 kms, whichever comes first. This is excerpt from 2012 Prius c, Canadian Owner's Manual Supplement:
    Both Oil and Filter and Maintenance services involve an oil/filter change:
    Here's a link to the full pdf:
    http://s3.amazonaws.com/toyota.site.p01/toyota/manuals/OMS1012U/OMS1012U.pdf
    Australia maybe is 10K kms or 6 months?
    #25 Mendel Leisk, Aug 30, 2018
    ztanos and Starship16 like this.
  6. roadrunner
    roadrunner His (blue) and hers (black).
    61
    36
    Perkasie, Pennsylvania
    2015 Prius c
  7. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Not sure, I thought it was Canada... but I obviously mis-remembered. :(
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Weird that it's 6 months 8k for the first 18k miles, then it's 16k after.
  9. Mendel Leisk
    41,428
    No, the schedule is confusing, but it's every 6 months or 8000 kms, always. Both "Oil and Filter Service" and "Maintenance Service" include an oil/filter change.
    FWIW, the fourth gen Prius goes to 16K or yearly.
    Personally, I would stick with 6 months or 8K regardless, it's my decision.
    Also, we have no freebie maintenance up here, nor the in-dash maintenance reminder. Almost a plus; life is simple. :)
  10. papafern
    62
    NYC
    2015 Prius c
    That's the link we need for the Prius C. Out car needs 0w20 only. That means that oil and filter change is every 10k miles. Every 5k tire rotation and fluid check. Thanks a lot!!!
    roadrunner likes this.
  11. Fred_H
    Fred_H Misoversimplifier
    558
    482
    28
    Germany
    Some car manufacturers install a computer program, called an Oil Life Monitor (OLM), in the car, which continuously monitors the operating conditions, and uses an algorithm to estimate how much the motor oil has deteriorated. Some people have reported that in favorable conditions, the OLM calls for an oil change at nearly double the standard schedule.
    A standard maintenance schedule can naturally only be a rough approximation of an optimum schedule for one's particular conditions. But for the vast majority, it is nevertheless close enough. For a few, who have special conditions, needs, or desires, there is also the option of used oil analysis.
    For most people, the savings from longer oil change intervals do not justify the cost and time of used oil analysis.
    I, for example, am one of the few who decided to use used oil analysis. I did it primarily out of curiosity, because I knew that I would probably recoup the analysis costs only after about 200k miles. With few cold starts, but many easy highway miles, and with long life motor oil, analysis showed that the oil was still good at 15k miles.
    roadrunner and Starship16 like this.
  12. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    My Gen4
    I'm glad I bought that Mobil 1 "Extended Performance", guaranteed for 15.000 miles. ;) :eek:
    (I might stretch it to 10.... but not 16. :LOL:)
  13. Mendel Leisk
    41,428
    I better not disclose the kms between oil changes I'm doing, you guys might try to have me committed... Suffice to say with the 3rd gen Canadian interval (6 months or 8000 kms), the 6 months invariably comes long before the kms. :whistle:
    ztanos and scona like this.
  14. papafern
    62
    NYC
    2015 Prius c
    The Walmart near me has the 5 quart 0w20 oil on sale for 25 bucks
  15. ShaAnn
    ShaAnn Member
    94
    42
    2014 Prius c
    My 2014 Prius c also has the banner that says maintenance required which shows each five thousand miles....I believe this is to remind us to rotate our tires if the oil was changed five thousand miles ago. I like the reminder but do not do oil changes until ten thousand miles has come.....my GEMA is running beautiful and I am very happy with her.
  16. Mendel Leisk
    41,428
    Honda's one example, with the Maintenance Minder. However there's a disclaimer in the Owner's Manual:
    (This is a 2010 Pilot O.M., just as an example.)
    roadrunner and Fred_H like this.
