Won’t go into ready mode
Discussion in 'Gen 3 Prius Technical Discussion' started by Jason Beauchamp, Jun 23, 2021.
  1. Jason Beauchamp
    Jason Beauchamp New Member
    25
    Lancaster, KY
    Just started having this issue, sometimes when I get in the car and push the power button it doesn’t go into ready mode, everything else comes on like when you push the button without applying the brake. I can turn it off and try again and still won’t go into ready. I can come back later and try it and it will come right on like normal. I have checked the 12v battery voltage when it did this and it was about 10.4, not sure why the voltage was that low either it has a fairly new dealer battery and seems to do this more often when I get in the car after work.
    52,829
    charge up the battery. if it won't hold 12.7v overnight, take it back for warranty replacement.
    another issue can be the brake light switch on the pedal, it might need adjustment.
    Jason Beauchamp likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,078
    6,939
    Texas Hill Country
    Or check for parasitic draw while off. Should be 15-30ma. 90ma or more can cause issues. Some have had several hundred ma which will discharge a battery quick.
