Wondering on how many 8KWh 2010 Prius??
Discussion in 'Prius PHEV Plug-In Modifications' started by banshee08, Sep 13, 2010.
  1. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Will be running only one 5000W converter. Running two converters just is not very efficient due to lots of energy lost to heat. I don't have any special ventilation but will look into it.
  2. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Neat project! I'm interested in only one aspect, though. Can the Firestone Coil-Rites be installed on the front springs as well to provide an equitable suspension raise across the entire vehicle?
    EDIT: I have to amend the above statement. The entire project is interesting but I am mainly looking to raise the suspension. Another exciting modification would be to install solar panels to supply power to the cells.
  3. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    There isn't enough surface area for solar cells to supply any significant power to the batteries. That's why the Gen III with solar package only runs a ventilator fan.
  4. vinnie97
    1,430
    277
    Somewhere out there
    Still haven't managed to procure anymore efficiency on modern panels, eh? I do recall seeing a solar panel prototype car recently and the entire surface of the vehicle was laced with panels. Well, that was only a comment as an aside.
    What I'm the most curious about is if those Coil-Rites can be used on all 4 springs as a means of raising the overall suspension. Anyone?
    EDIT: Truckspring.com personnel informed me that the Firestone spring helpers won't raise the suspension, only keep it from dropping under heavy weight (as it's being used here).
  5. pbui
    pbui Member
    190
    Los Gatos, northern CA
    Banshee - I have toying with the idea of installing the converter in the wheel well, with its own in and out air flow ports. I think it's a bad idea to keep the converter cooped up inside a box with the battery, with all that heat capacity.
    In your dual converter configuration, what are the output voltage for each converter ? do you turn converter on/off independently ?
    Tx
  6. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    I have been thinking about how to put two converters in the tire well also and make my own ventilation for them also. Eventually I like to see if I can swap out my 8kwh of batteries for some other 180ah battery and make my own custom case to house everything. I think I can save lots of space if I can use 16 200ah thundersky or 16 180ah sky energy batteries instead of my current setup.
    My old dual converter setup is independently switched. The voltages were all set to 242V on both. But currently I am running just one 5000W converter and I have to say my MPG is not fairing well compared to one 3000W converter. I will run it for an entire tank and switch back to make a comparison. I may just move back to two 3000W converter..
  7. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Are you saying that the 5KW inverter can't keep up with a single 3KW inverter or did you mean 5KW can't keep up with 2 3KW inverter.
  8. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Maybe my 5000w converter is just not right.. There is lots of thermal shut down on my converter.. Much more off time than my single 3000w converter..enough to lower my mpg.
