Won't run after battery repair
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by leifbert, Jul 31, 2017.
  1. leifbert
    leifbert Junior Member
    Naples
    I replaced a bad battery module on my 2004. Now when I push the brake pedal and start button, all the warning lights come on and I only have park and neutral. I verified that my disconnect switch is pivoted and firmly pushed down. I have 235 volts at the hybrid battery and 12.6 on the little battery. The 12 volt battery passes a load test as well. I searched the forums and have had no luck. Thanks for any guidance.
    Gambitsource likes this.
  2. JC91006
    16,936
    8,647
    What's your process in fixing the battery? How did you identify the bad module? Did you check all the modules in the battery pack?
    Raytheeagle likes this.
  3. leifbert
    Naples
    I had a code showing block 4 was bad. I removed the hybrid pack and checked the voltages individually. The first module in the block 4 module only had 6 volts. Every other module was in the 7.8 range. I put in a good module showing 7.8 volts and reinstalled the pack.
  4. leifbert
    Naples
    I scanned the hybrid computer and got the following: Prius pack code.jpg
  5. leifbert
    Naples
    POAA4 AND POAA1
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Curious about the 235 volts. That's smokin' high. There's only 28 modules so that would be 8.4 volts per module. Well above normal voltage.
    Maybe a connector got missed during reassembly. Odds are very slim you have true multiple faults. One that commonly gets missed is the one that connects directly under the disconnect switch, but more likely it's one of the other connectors not pushed in completely.
    That's my guess as a keyboard warrior.
    #6 TMR-JWAP, Jul 31, 2017
  7. leifbert
    Naples
    I googled my issue and used POAA4 AND POAA1 as well as P0AA4 AND P0AA1
    I used a zero in one version and the letter o in the other. This made a difference in my search results. I found the following post: EDIT (I was not allowed to post the link)
    The bolt with the arrow was not installed in my haste. Installing it fixed my problem!
  8. bisco
    52,863
    congrats!(y)
  9. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    All the other case to car body bolts were installed except that one? And installing that one cured the problem?
    Or did you just have the battery sitting in place for testing with NO case to body bolts installed?
    I suppose since the photo shows the battery in place without the case cover, the latter condition would be true. The cover can't be removed until the case to frame bolts are all removed. I think member ericbecky has stated several times on the forum that he always installs a minimum of 2 bolts to ensure the battery case is grounded when he's performing testing. Now we see why.
    #9 TMR-JWAP, Jul 31, 2017
  10. leifbert
    Naples
    I had the cover installed and all the bolts except this one. I removed the cover looking for the problem. The missing bolt is the one close to the relay green ground wire. I have quite a bit of corrosion at the battery retaining bolts that probably added resistance to the ground path. Wow, I can't believe how much better the car runs without a bad module.
  11. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Glad to hear you got it sorted out. And we now have a bit more info for the next person that runs into that problem after working on the battery. I'm sure you weren't the first and won't be the last. But now we've learned a bit and can help faster.
  12. GodIsAmazing
    GodIsAmazing Junior Member
    Yes, Yes Yes! This is so true and so simple. I had the red car light and the hybrid battery contractors were not engaging, grounding is important
  13. Gambitsource
    Gambitsource New Member
    22
    San Diego
    In my case guys, the battery was all connected correctly and still the dash has all the lights displaying. At worst the car also will not start. I would really love the help on this one.
  14. JC91006
    16,936
    8,647
    1. check your 12v battery to make sure it has enough juice to start the car
    2. Make sure your hv battery orange interlock is locked into place properly
    SFO likes this.
  15. Gambitsource
    22
    San Diego
    Here's the thing about the 12V battery. I checked the volts on a multimeter when disconnected from the car. It read 12.4 V and when I have it connected and the car turned on it reads 11.4 V and sometimes different. Would you say the battery is working properly?
    Second, I have a 2007 Prius and I pulled the HV battery out and replaced 2 modules. When I put the battery back in the car and confirmed all bolts are on and the orange interlock was secured. The car showed this in the picture. The funny thing is I pulled out the battery again and turned the car on and the same dash lights came on. I would think this would mean the HV battery was not making contact with the 12V or computer system to the car. Idk.. Your thoughts.
  16. JC91006
    16,936
    8,647
    1. You should think about charging the 12v battery and then have it load tested for free at any auto shop. It may be weak, but I don't think that's your issue for now.
    2. Have you bolted down the battery to the car? Or it's just sitting there without any bolts in place? It won't work unless there are some bolts bolting it down for the ground.
  17. Gambitsource
    22
    San Diego
    Here is the pics from the 12V. Starting from battery disconnected- 12.27V , When the battery is connected and car not running- 12.13V, the battery when car is turned on- 11.81V
  18. Gambitsource
    22
    San Diego
    I will try charging the battery and I can try to get it to a shop.
    I have the Aux battery bolted down with the casing that comes with the car. I can try to tighten them really tight. I just have a weird thing going on with the positive side that has the red fuse/relay box. I always have to unplug the battery to see the dash lights or sometimes pull out the power clip from the fuse/relay box. Then the car would start with everything working properly. Of I am talking before I worked on the Hybrid battery. :(
  19. dolj
    dolj Senior Member
    8,652
    4,402
    Wellington, New Zealand
    Here's the thing about the 12V battery. Check the quiesced current draw, it should be anything from 500 mA to 20 mA, depending on the stage of quiescence.
    If you find the quiescent current draw is within spec and you saw the voltage difference on a multimeter between disconnected from the car and connected to the car was a whole volt (or more) different, then I would be suspecting the battery needs replacement.
    If the quiescent draw is significantly higher than above, you will need to track down the source of the parasitic drain, otherwise, you will forever be changing the 12 V battery.
  20. Gambitsource
    22
    San Diego
    I just replaced a couple modules in the Hybrid battery and arranged them so the middle of the battery would be the highest in voltage.I made sure I tested the full battery and read 213.0 V. After reinstalling the battery in the car the car will not start the engine. I get a reading on ODMII the Aux battery is 11.6 V. At this point would you say replacing the battery should start the car or do you think I have other problems going on?
