wont start after 3 warning lights came on!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jsquick123, Sep 24, 2018.
  1. jsquick123
    jsquick123 Junior Member
    Pennsylvania
    I have a 2005 prius and i just hit 180,000 miles on it. I've had it for over a year now and i havent had any major problems. This morning i started it and the brake, master, and hybrid battery lights all came on. I got to my destination and then later when i started it again, and the ready light and the odometer didnt come up so it wouldnt run. so now it's stuck at my school and I dont know what to do!! the 12V battery was replaced 2 years ago, the oil was changed about a month ago, the water pump was replaced a few weeks ago, and it was running fine till now...help!!!!
  2. jsquick123
    Pennsylvania
    UPDATE: I just checked the 12V battery and the battery tester came up as recharge and dead but the thing is that all of the auxillary things come up (the radio, lights, dashboard, etc). Could it be the 12V battery even though it is telling me that it's the hybrid battery??
    52,785
    you will have to take it to a dealer and have the trouble codes read. could be the 12v, oil level, inverter pump, hybrid battery, brake actuator, combo meter, and/or more.
  4. jsquick123
    Pennsylvania
    the trouble codes would tell exactly what is wrong with it?
  5. bisco
    52,785
    no, the trouble codes are used along with the service manual and the included diagnostic tree to lead you to the culprit(s)
    sometimes, if you're lucky, posting the trouble codes here may bring an answer. some issues are more complicated than others.
  6. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Didn't he say the 12v was bad??
