Won't Start- Batteries fine, all lights and dash except speedometer work fine
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Priuprap, Jun 29, 2018.
  1. Priuprap
    Priuprap New Member
    Arizona
    Hello
    My 2012 prius v won't start. Everything turns on (headlights, brakelights, dash, ac) except the engine and the speedometer is blank. In fact, all the indicator lights stay on all at once, emergency brake light, no seatbelt, etc, everything except the speedometer. When I try to shift into reverse or drive it shifts to neutral and the light flashes to return to park. I tested the batteries with a voltage reader and both read alive and well, so it's not the batteries by themselves. The battery indicator reads at two bars currently.
    Anyone have any ideas? I though early on it might have something to do with the immobilizer because the keys were left in the car overnight but now i'm skeptical of that explanation.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,979
    4,718
    Texas Hill Country
    I have seen badly connected 12 v battery or a bad inverter block Ready but still allow nuetral.
    Raytheeagle likes this.
    49,500
    welcome!
    ipm module?
    Air_Boss and Raytheeagle like this.
  4. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Meaning was the circa 2016 recall for the IPM done?
  5. Robert316
    Robert316 New Member
    Brisbane Australia
    ----Australia----
    Hi I also had encountered the same problem. May I know what might be the problem and what is the solution? Thank you.
  6. rjparker
    7,979
    4,718
    Texas Hill Country
    After checking the 12v battery voltage (at least 11.8 v) I would read codes. There are many possibilities.
  7. therealdana
    therealdana Junior Member
    the moon
    2013 Prius v wagon
    was this resolved? i have the same issue right now and could use the help before towing to the dealership. i replaced the 12V and the key fob battery. exact issue you've described here. all the lights are on but the engine won't start.
  8. rjparker
    7,979
    4,718
    Texas Hill Country
    I like to recommend good independent shops but the outposts on the moon are all closed. Sometimes it takes several tries after a battery has been replaced, assuming the measured voltage is better than 11.75v and no other issues were preexisting.
  9. therealdana
    the moon
    2013 Prius v wagon
    haven’t you seen that cube on the moon? ;) that’s Marvin’s Motors! good shop!
    thanks for the tip. i’ll give it another go tonight after work.
