Won't Start - No lights, No response, No noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jlspartz, Jul 6, 2015.
  1. jlspartz
    jlspartz Junior Member
    WI
    I drove my '05 car no problem Saturday night. I went to start it up Sunday and there was no response at all. There's no dome lights, no dash lights, no power button light, nothing... I don't think any light was left on. The 12v battery was replaced about 1 1/2 years ago. I tried jumping it at the front terminal under the hood but still no response. I checked the 120A fuse connected to the 12v battery and it looks fine. I know there's also a 5A small fuse by the 12v battery, but by this time it was getting too dark to check it. Any suggestions?
  2. alekska
    alekska Active Member
    435
    138
    Atl
    Use multimeter. Check the voltage at the terminals under the hood (engine/ground to positive terminal) and at the battery terminals , and tell us. That would be a start of the troubleshooting
    Alex
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    looking at a fuse isn't a good test. you got to use a meter. also that 12v battery might have an internal short or something.
  4. jlspartz
    WI
    I thought I bought a multimeter a couple years ago, but can't find it since moving 6 weeks ago. I'm going to pick a new one up tomorrow, and I will post the results. Thanks!
  5. Patrick Wong
    18,210
    6,517
    Try turning on the headlights. If they do not work then you have a problem with the 12V battery or the 120A MAIN fuse. It would be very unusual for that fuse to blow.
    With the jumper cables applied at the jumpstart terminal and unpainted body metal, see if the headlights will turn on. If they do not then there may be a problem with the way you've connected the cables.
  6. JC91006
    16,936
    8,647
    Do you know how to connect the jumper cables to the terminal in the front of the car? The positive goes on the terminal, the negative goes on an unpainted part of the engine.
    I suspect you have a dead 12v battery
  7. bisco
    52,821
    buy a cheapo multimeter.
  8. jlspartz
    WI
    Wow, it's 0.88v at the battery, and 0.5v at the front terminal. I only tried jumping for 2 minutes before. Not sure if it can be saved from complete discharge...
  9. jlspartz
    WI
    Just got it going again!
    Jumping it from the front under the hood terminal wasn't doing anything. Even while jumping, checking the voltage at the battery it was still 0.88v. I watched 3 videos, all of them showing the same way. The second I hooked up the live car battery to the actual battery in the back the dome door light went on, and it was up and running in a few minutes. I don't know why the terminal under the hood was not working for me.
  10. Patrick Wong
    18,210
    6,517
    When the Prius is READY, measure the voltage across the 12V battery as well as at the dedicated jumpstart terminal, to body ground.
    You can try to charge the battery overnight, but you will probably find that it is time to buy a new 12V battery or get a replacement under warranty.
  11. bisco
    52,821
    congratz!
  12. Mygirlsprius21
    Mygirlsprius21 New Member
    Cranston ri
