WONT START NO POWER
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Misty Stanford, Aug 17, 2018.
  1. Misty Stanford
    Misty Stanford Junior Member
    Thibodaux, LA
    Three Touring
    I have a 2008 prius touring. I drove home from work yesterday evening with no issues at all. I went to leave for work this morning my car unlocked, I put my foot on the brake, pressed the start button and the dash lights came on but nothing else tried to turn off the car and that didn't work. it was like nothing had power. The dash lights eventually went out but my nothing would function. Please Help!
  2. JC91006
    16,936
    8,647
    Maybe your 12v battery is dead
    edthefox5 and Raytheeagle like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    x2.......
    Experienced something very similar with a 2005 I just purchased. Car sat for 5 days before I had a chance to work on it. Battery was at 9 volts.
    52,847
    if not, you might have a bad multi information display. test the battery first, how old is it?
  5. Misty Stanford
    Thibodaux, LA
    Three Touring
    I'm not sure hold old the battery is. It was in the car when I bought it used 3 years ago this May. I will be taking it out soon and trying to slow charge it to see if it'll hold a charge
  6. Misty Stanford
    Thibodaux, LA
    Three Touring
    So I took the battery out and put it on a trickle charger and immediately it read it the green and shortly after showed fully charged.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    That’s to bad that means it’s not the 12 volt battery. When this happens to a Prius it logs a lot of trouble codes that will tell you exactly what it’s unhappy about. Much time and money and consternation can be be done chasing a supposed issue.
    Auto parts stores free obd tests from what I see on this forum are unable to pull hybrid codes.
    Best place for codes read is the dealer that costs $145 in my town.
    Plus a tow.
    Get all the codes in writing and post them back here before you ok them to go anything.
    If you don’t need the car fast use the search forum button up top and search
    Techstream
    Which is the software used to read the codes. Lots of Cheaper alternatives to decode the codes but cost time.
    Good luck.
    Naurill likes this.
  8. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    This is not necessarily true. Don't just arbitrarily trust the green light on a slow charger/maintainer. I also used a 1.5 amp slow charger and had to restart the charge about 4 times because (I'm assuming) the voltage was so low it was triggering false indications of being fully charged after only about 15 minutes of charging. After the fourth start it stayed charging and didn't turn green until during the night. I had started around noon, as I was pulling the interior out to remove the HV battery.
    And curiosity got the better of me. I went to look at my slow charger. It's a Schumacher XM1-5-CA. It's a 6v/12v automatic charger. Apparently if the voltage is low enough on a 12v battery, it assumes the battery is a 6v battery and that's what causes it to give a false indication of fully charged. Maybe the OPs charger is similar?
    #8 TMR-JWAP, Aug 19, 2018
    jerrymildred, dolj and ITBland like this.
  9. JC91006
    16,936
    8,647
    If the battery that normally takes 10 hours to charge, completes the charge in 2 hours, then the battery is bad.
    edthefox5 likes this.
  10. bisco
    52,847
    have you tried the charged battery yet?
  11. bisco
    52,847
    have you put it back in the car?
  12. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    You could take the battery to a parts store and have them test it.
    Naurill and Misty Stanford like this.
  13. Misty Stanford
    Thibodaux, LA
    Three Touring
    I decided to take it to Auto zone to test the battery it was only reading a 26% charge. I'm assuming I was getting false reading on the charger. They were able to charge it up for me and my car is running perfectly again!! Thanks so much to everyone for the help!!!
  14. bisco
    52,847
    great!
    i would get a volt meter and keep an eye on it, so you don't get stranded.
    prius battery is usually damaged to some extent after deep discharge, especially as they age.
    ITBland and Naurill like this.
  15. ITBland
    433
    278
    Raytheeagle likes this.
  16. Naurill
    Naurill Junior Member
    59
    25
    United Kingdom
    Great idea ITB. I have a couple of regular, heavy lead acid battery options (a small 'garden,' think golf cart, battery and a cheap booster pack), but I take them out of the car most of the time as they are heavy to lug about. The lithium battery pack might be a bit of a pain to keep charged, but a lot less mass.
    #16 Naurill, Aug 21, 2018
  17. ITBland
    433
    278
    Lithium ion batteries loose very little charge sitting around, they are perfect for this purpose (except for that bursting into flames issue they sometimes have :eek:)
    #17 ITBland, Aug 21, 2018
    Naurill and edthefox5 like this.
