Won't start unless brake pedal all the way to the floor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tls1, Jun 10, 2014.
  1. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
  2. tls1
    tls1 Junior Member
    17
    I did go to a second Toyota Dealer in Salinas Ca. and they were very helpful. Pedal still goes all the way to the floor when ICE is off but work perfectly when moving. The dealer said everything is working normal.
    51,897
    really? i never noticed that.
  4. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    OP: you didn't mention if you could hear the brake booster engage when you open the driver's door after you replaced the 12v battery. The noise should go on for a few seconds - especially after the car has been idle for several hours. If you don't hear it, something is still wrong. Also, try a panic stop at about 30 mph on a road with no traffic. You'll know then if you have a brake problem or not.
    Feri likes this.
