Won't start when key is inserted in slot
Discussion in 'Newbie Forum' started by clouie, Jun 1, 2016.
  1. clouie
    clouie New Member
    Los Angeles
    I got the opportunity to get myself a 2006 Prius. I am surprised with the 52 mpg that I get for it's age. It came with one key so googled and found myself here. Been reading around and posted at the chicken dance but I think I have a different issue (will delete the other post if required)... I only have one key and it scaring me if something happens to it. The issue I'm having is that, the car won't start if the key is inserted in the slot (flashing LED car on the dashboard continously). What I don't understand is that it works the "smart" way... having the key around without inserting and I can start the car. Reading thru posts it should be the other way around. I have scanned thru the manual a couple of times and can't find anything. I surely hope it is an easy thing but would love to know why it is not working when inserted. Did anyone have experienced this? Can someone give me any assistance on how to approach this issue? Thankls in advance for any
  2. JC91006
    16,937
    8,647
    You have a replacement key that was partially programmed. I believe the only way to get it working in the slot, would require a reseed of the keys. That should be around $200 at the dealer.
    You can also program a 2nd key at the same time
  3. clouie
    clouie New Member
    Los Angeles
    Ouch... but now I know what to do. Thanks.
  4. JC91006
    16,937
    8,647
    I almost never use the slot, so probably not worth it.
  5. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    But the second key is a really really good idea, actually I would call it a must.
