Won't stay running, P0341 and P3190
Discussion in 'Gen 2 Prius Technical Discussion' started by way2coolwheels, Oct 6, 2018.
  1. way2coolwheels
    39
    42
    The Prius from hell LIVES! Next step is to get the airbag light problem fixed....
    TomB985 and Raytheeagle like this.
  2. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    How did you solve the "Won't stay running, P0341 and P3190" problems?
    Any known DTC(s) for the airbag light problem?
    Raytheeagle likes this.
  3. way2coolwheels
    39
    42
    Well, since replacing the fuel tank/pump, it's been running great and no more check engine light. I haven't rechecked for codes, so I am assuming that the cam code was set due to the erratic idle with the low fuel pressure.
    The airbag light has been on since I got the car, and I don't recall the exact code number. I do remember that it was a code pertaining to the drivers side bag having an open circuit. I also noticed that at times when the steering wheel was at a certain angle and the car turned on, the light would go off. This led me to believe that the "Clockspring" in the steering column was to blame. I found a new one for only $7 on eBay, so I bought it. When I get a chance, I'll install it and see if that's the problem.
    Raytheeagle and SFO like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Just a note that the cheap clock spring is not very reliable.
    There are threads on here of owners having to go back in after the repair to do it again.
    Good luck and keep us posted (y).
  5. way2coolwheels
    39
    42
    Thanks for the heads-up!
  6. Prodigyplace
    12,564
    11,779
    Central Virginia
    Not only that, but they could be fatal if they do not activate the airbag when needed.
    Skibob likes this.
  7. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Plenty of places to save money on parts. Airbags are not one of them. Car is so small you already are at a disadvantage against most cars.
    way2coolwheels likes this.
  8. way2coolwheels
    39
    42
    After putting almost 2000 miles on it, all is well. Engine runs great, no longer consuming too much oil. And as a side benefit, the catalytic converter appears to be working properly now, probably because it is no longer being soaked in oil. I cleared codes, and the check engine light remains off, no further codes being set. YAAY!
    I also replace the clock spring, no more airbag light, as well as curing my intermittent cruise control problem. Easy fix.
    With the car fully functional, I might just keep it, LOL!
    SFO and Raytheeagle like this.
  9. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    Thanks for posting the solution! Fuel pump makes perfect sense for your symptoms. Where did you source the replacement tank?
  10. way2coolwheels
    39
    42
    TomB985 likes this.
